Technical => Engine Tech => Topic started by: cougar1car on July 02, 2007, 06:47:59 PM
Title: Questions???
Post by: cougar1car on July 02, 2007, 06:47:59 PM
Well only maybe one question. How hard would it be to add the supercharger from a supercoupe to my 3.8 88 cougar, if at all possible and by all means tell me if this sounds like a dumbass idea. I want a little more get up and go but dont want to go through the hassle of changing the motor quite yet. :flame:
Title: Questions???
Post by: Prototype Services on July 02, 2007, 09:22:14 PM
Just wait and change the motor.
Title: Questions???
Post by: vinnietbird on July 02, 2007, 09:29:41 PM
X2
Title: Questions???
Post by: 84 Fila on July 02, 2007, 09:35:47 PM
x3
Title: Questions???
Post by: cougarcragar on July 02, 2007, 09:53:12 PM
I think you would grenade your stock 3.8 by adding forced induction. I wouldn't even try it.
Title: Questions???
Post by: cougar1car on July 02, 2007, 10:32:00 PM
OK i guess so far its a no. Why you think it would suk to do it. Motor seems to run strong has 75000 miles on it. Just wondering why
Title: Questions???
Post by: Red_LX on July 02, 2007, 11:29:14 PM
I'll take a shot in the dark and say...because the engine isn't made for forced induction? Cast pistons and all that sort of .
Title: Questions???
Post by: cougar1car on July 02, 2007, 11:31:06 PM
Ok I was just asking.
Title: Questions???
Post by: thunderjet302 on July 02, 2007, 11:40:04 PM
Supercharged 3.8 V6s have forged crank, rods, and pistons. They also have a beefed up block and better head gaskets. If you put a SC blower on your stock 88 3.8 it'll go *boom* :flame:
Title: Questions???
Post by: cougar1car on July 03, 2007, 11:24:04 AM
Ok well BOOM is not my intention thats why I figured i would ask people who know more on it than I do. Thanks guys .
Title: Questions???
Post by: V8Demon on July 03, 2007, 05:23:00 PM
Why don't you star with things you can use now while you await this other motor.  For instance....Step #1:  3.73's
Title: Questions???
Post by: thunderjet302 on July 03, 2007, 05:30:03 PM
Quote from: V8Demon;158319
Don't forget a Traction-Lok diff as well;)
Title: Questions???
Post by: V8Demon on July 03, 2007, 05:35:44 PM
He may already have it.  Most V6 87-88's did.  Mine did.
Title: Questions???
Post by: bhazard on July 03, 2007, 06:09:03 PM
Just swap in a TC rear.
Title: Questions???
Post by: 84 Fila on July 03, 2007, 06:12:44 PM
Quote from: V8Demon;158321
Did have what, the TL or the 3.73's?
Title: Questions???
Post by: jcassity on July 04, 2007, 09:09:23 AM
that would have been a nice surprise for me to find,,,,,,,,,,,instead of 3.08.
Title: Questions???
Post by: CougarSE on July 04, 2007, 10:02:46 AM
I think most 88's had it as apposed to 87's...
The stock n/a block can handle about 7psi before it goes boom.  Not hardly worth it considering its not hard to make a decently tuned SC engine do twice that.
The wiring harness is the bitch part.  There is no drop in, easy convert way of doing things...
Title: Questions???
Post by: Cougars 2 go on July 04, 2007, 10:05:11 AM
Quote from: cougar1car;158157
1988 Mercury Cougar Special Edition 3.8 Bone Stock for now....
You're killin me. See my other post:
http://www.foxtbirdcougarforums.com/showthread.php?p=158472#post158472
Title: Questions???
Post by: cougar1car on July 04, 2007, 11:32:55 AM
Well like I said in the other thread the motor is satying like she is for now. Probably will never get a change the one thing I want done is the 5 lug swap. How would I tell which rear end I have gears and what not.
Title: Questions???
Post by: V8Demon on July 04, 2007, 11:56:20 AM
Check your axle code.  It should be on the sticker on the inside of your door.  Check the Coolcats website afterwards to see which code matches yours and that will be the setup you have (as long as nobody changed it)
Title: Questions???
Post by: cougar1car on July 04, 2007, 11:21:31 PM
OK ill check that tomorrow and see what I come up with.
Title: Questions???
Post by: cougar1car on July 05, 2007, 12:00:55 PM
I know weve moved away form engine tech but heres a pic of my door tag anyone have an idea??
(http://[IMG]http://i188.photobucket.com/albums/z14/cougar1car/doortag2.jpg)[/IMG]
Title: Questions???
Post by: cougar1car on July 05, 2007, 12:03:04 PM
Ok I looked it up guess I got the 3.08 gears in the axle. Non locking
Title: Questions???
Post by: bhazard on July 05, 2007, 12:06:40 PM
3.08, my guess is open too.
edit: doh
Title: Questions???
Post by: cougar1car on July 05, 2007, 12:17:58 PM
Does anyone else know what all the other stuff means??? Like the letter under the R or any other of the numbers or letters on there??
Title: Questions???
Post by: 5.0willgo on July 05, 2007, 12:34:18 PM
The R is the radio code.
The  Int./Trim is your interior code - cloth individual seats, smoke color.
TR is your transmission code - AOD
Body 66D is the body code.
Exterior paint - 1C Black
Title: Questions???
Post by: cougar1car on July 05, 2007, 01:00:18 PM
What about the 16 above the DSO and the TCCDD under the tr.    F0095, R0026????
Title: Questions???
Post by: EricCoolCats on July 05, 2007, 01:04:38 PM
Interior trim (DG) = Smoke cloth individual seats
(more info: http://www.coolcats.net/fox/1988colors.html)
66D = generic Cougar body code, carried over from the 1983-86 body style. Starting in 1987 the actual body order code is incorporated into the VIN (60 = LS).
Under TR is 5 characters. The first is the actual transmission code (T=AOD). The other four are your suspension's spring codes (C=front left, C=front right, D=rear left, D=rear right). I think Chuck W might be able to decipher the spring codes better. I have the codes in one of my shop manuals, but they don't translate into spring rates or anything else useful, for that matter.
Title: Questions???
Post by: cougar1car on July 05, 2007, 01:53:14 PM
Thanks alot. its nice to know what some of the stuff means.
