Marketplace => LEADS on T-Bird/Cougar Stuff For Sale => Topic started by: Carl on June 29, 2007, 01:25:34 AM
Title: MINT 20th Anniversary Cougar
Post by: Carl on June 29, 2007, 01:25:34 AM
http://philadelphia.craigslist.org/car/355410234.html
I want it! :cougarsmily:
Post by: daboss351 on June 29, 2007, 02:10:08 AM
when did these cars come with heated seats? never knew that was an option
Post by: Royce 67/87/97 on June 29, 2007, 02:40:21 AM
It (heated seats) was only offered on the 20ths. Not even an option (as just about everything was offered as "standard" - the only options available on the cars were:
[LIST=1]
The moonroof, of course, is the most "rare" of the three options on these cars. Most 20ths I have seen usually have either the keyless entry or the ATC, or both.
Post by: EricCoolCats on June 29, 2007, 09:35:15 AM
Ahem... ;)
REGULAR PRODUCTION OPTIONS
45A Traction-Lok axle
573 Automatic temperature control
91H Power antenna
47J Illuminated entry system
144 Keyless entry system
21B Power moonroof
NOTE: 47J and 144 required to be ordered together.
LIMITED PRODUCTION OPTIONS (DEALER INSTALLED)
Engine block heater
Front license plate bracket
http://www.coolcats.net/fox/20thanniversaryoptions.html
Post by: Royce 67/87/97 on June 29, 2007, 03:15:14 PM
My bad, Eric - I was just going by what the salesman said 20 years ago. I was unaware of the Traction-Loc, power antenna, or illuminated entry as options. Mine's got everything but the sunroof, and I thought that was the only thing she was "missing."
Now, I am actuallly not sure about the Traction-Loc axle. Waht is the easiest way to determine if my car is equipped with tat option or not? Thanks/
Post by: EricCoolCats on June 29, 2007, 03:21:49 PM
Royce, I'm just bustin' your nuts. :punchballs:
What you said about there only being three options, EVERYONE used to say. I've heard that myself for 20 years. It was just a common-knowledge thing for some reason. But once I found the dealer order page for the 20th model, it became clear that there were more than 3 options for the car. A "stripped" 20th is still pretty loaded up. But to get the ultimate factory 20th, you'd have to have ordered everything on that list.
Your axle code is on your door tag; should be above AX. List of codes here:
http://www.coolcats.net/tech/general/axleinfo.html
Post by: daboss351 on June 29, 2007, 03:30:14 PM
or just spin um up!!!!!
so he saying heated seats, and i was right in assuming those were never offered?
Post by: BCA on June 29, 2007, 05:34:54 PM
Quote from: daboss351;157584
He is saying that they were standard equipment on the 20th, and were not even offered as an option on Cougar LS or XR-7.
Brent
:cougarsmily:
