I have not been able to find the wires to hook up scanner i had used it afew years ago I hooked up to it but now its gone! started having problems after changed driver side valve cover pulled the upper intake car runs good but hesitates and uses more gas way too much but eng lite come on sometimes and run better and sometimes eng lite does not come on when i first start it and idle is bad i just turn it off once or twice and eng lite comes on and idles better any help is appreciated i had mt silver cougar over 8 years thank maybe emision problem! A photo would be great i belive my wire got stuck under something or got cut off!
My brain hurts from reading that.
all that I can say is my hook ups are alittle bit from the fire wall on the dirvers side. They were fairly easy to find. I found them my first time looking, and I never had seen them before. If you have the right scanner then you can find the shapes of the plug thingy's by looking at the scanner input thingy and just find wires that look like that.
Tomz... Please pick up a grammar book and read it.... My head hurts as well. Ok, after regrouping.... The single wire usualy comes out of the same place on the harness as the big connector. Unless you have untaped the harness for any reason it should be very close by.
Ask, and ye shall receive.....
(http://www3.telus.net/neat/pics1/eec_test_plugs.jpg)
to CougarSE It seems to me your understanding of lifes things are retricted by self imposed limitations THANKS ANYWAY TOMZ! This will never be a perfect wolld !
I think MexCougar has a better grasp of the English language than tomz...
Is this some kind of inside thing? Did I miss something or does no one else understand either?
Tom, if I understand correctly you started having some issues AFTER replacing your valve cover gasket? You need to recheck your work as I think you've either forgot to hook something up or you broke a vacuum line?? Just a thought:)
Thank you very much MasterBlaster for rhe photo. The single wire that I was looking for was behind the brake booster. Now I will be able to hook up a code scanner.
Lowcat, In this imperfect WORLD I don't understand anything because I use good grammar. That must be it, yea must be. <---See that! Thats a period! That makes me understand JACK!
I don't know...... Really. Atleast he can get his car fixed.
