Technical => Electrical Tech => Topic started by: SLEEPER T-BIRD 87 on June 15, 2007, 12:12:39 AM
Title: Digital dash and H.O swap
Post by: SLEEPER T-BIRD 87 on June 15, 2007, 12:12:39 AM
dont know if there related  my speedo doesnt work
(lights up and displays 0 mph) any ideas?  car is an 87 cougar 5.0 full digi dash
Post by: 32VFoxBird on June 15, 2007, 01:21:12 AM
bad vss or chewed up driven gear would be my guess.
Post by: raser13 on June 15, 2007, 03:29:35 AM
my guese is if it stoped working all of a suden, it most likely the clip that plugs into the sender on the tranny came undone youmay of had something fly up and knockit off.
Post by: SLEEPER T-BIRD 87 on June 15, 2007, 08:51:33 AM
Quote from: raser13;154393
i just bought the car i have no idea if it worked before
Post by: thunderjet302 on June 15, 2007, 01:26:24 PM
Eh mine works fine:D . Check the VS sensor on the trans. Either it or the gear is messed up. Also if you drive it for a bit the *average speed* part of the trip computer should say something other than 0 mph. That should let you know if you're getting a signal or not.
Post by: SLEEPER T-BIRD 87 on June 15, 2007, 06:52:29 PM
Quote from: thunderjet302;154460
well the average speed dont work so i guess its a wiring issue or the Vss
Post by: raser13 on June 15, 2007, 07:14:03 PM
i'd still check the clip underneath the car. but it might be the circut tape on the back of the cluster they like to get brittle. kind of like what happened here:
http://www.foxtbirdcougarforums.com/showthread.php?t=14080 (http://"http://www.foxtbirdcougarforums.com/showthread.php?t=14080")
Post by: thunderjet302 on June 16, 2007, 01:40:32 AM
Quote from: SLEEPER T-BIRD 87;154526
Yep
Post by: SLEEPER T-BIRD 87 on June 16, 2007, 05:12:16 PM
FIXED! someone cut the VSS wires at the trans
