Marketplace => T-Bird/Cougar Parts & Cars FOR SALE => Topic started by: Ether947 on June 12, 2007, 07:33:08 PM
Title: Walbro 190lph Pump
Post by: Ether947 on June 12, 2007, 07:33:08 PM
Any interest in this? As indicated in this thread (http://"http://foxtbirdcougarforums.com/showthread.php?t=13980"), it could be faulty or it could of been the IRCM wiring. After chatting with cougarman, the IRCM pins could been slightly damaged when the bracket was modified for the BPV. And since I have the tank down I may as well upgrade to a Walbro 255 HP Pump as I have been bitten by the turbo bug. Don't want to run out of fuel now do we? :D
With that said, if you don't mind the history how about $35 shipped?
ether947@gmail.com
Post by: vinnietbird on June 13, 2007, 05:19:44 PM
Is there some way you can hook up a couple of wires top it and check it out?I may be intersested.
Post by: Ether947 on June 13, 2007, 05:33:35 PM
It worked until I dropped the tank. Even under 19lbs of boost. I thought about putting it back in, but since I have the tank down...
Post by: vinnietbird on June 13, 2007, 06:07:27 PM
PM sent
Post by: Ether947 on June 14, 2007, 01:11:10 PM
Sale Pending...
