Technical => Electrical Tech => Topic started by: Chuck W on June 11, 2007, 10:14:17 PM
Title: 83-84TC tach modification - input needed
Post by: Chuck W on June 11, 2007, 10:14:17 PM
OK, I have an instrument cluster from an 83-84TC in the '80 XR-7.  Great, right?
Anyway, obviously the tach is set up for a 4 cyl engine, but the XR-7 currently has a V8 and eventually will have a V6, so I want to make the tach useable instead of having it read 50-100% higher.
I'm just trying to figure out the "best" way to alter the signal and perhaps make it adjustable to boot.
I have a tach from a 79-80 turbo Mustang and those had a small adjustable pot on them which could be used to "adjust" the input signal, but the 83-84 TC tach does not.  Of course electronics is not my strong suit and I'm trying to sort out what resistor to replace, or figure out a way to alter the signal before it gets to the "SIG" input to the tach itself.
Is it possible to put a resistor in the line from the coil to the tach?  Will that reduce the signal impulses?
Anyone modified one of these, or something similar?
Post by: Thunder Chicken on June 11, 2007, 11:40:13 PM
Chuck - I do know that a resistor inline with the coil will not work - the tach works by counting pulses, not by the strength of those pulses. You would have to replace a resistor or capacitor (or both) on the tach's circuit board to modify it. Without having one to play with I'm afraid I can't offer much help other than that...
Post by: Sduneman3 on June 12, 2007, 12:35:43 AM
here's it on Eric's Site http://www.coolcats.net/tech/advanced/4to8tach.html
but, it's only for the 87/88.  When you do find out, let him know, so he can get it on his site
Post by: Chuck W on June 12, 2007, 09:44:43 AM
Quote from: Thunder Chicken;153680
Yeah, I kind of figured that.
I'm guessing I need to figure out which resistor on the board alters the SIG before it hits the chip (OP AMP?).
Post by: 84 Fila on June 12, 2007, 09:46:16 AM
I have no clue what that means, but if you figure out a mod, let me know. I would love to have a stock guage pack in my dash. 83-4 TC is the same look just with a tach.
Post by: bhazard on June 12, 2007, 10:59:21 AM
Youre swapping to a V6? Of what sort?
Post by: 84 Fila on June 12, 2007, 11:00:29 AM
Me or chuck? I think he's doing the SHO V6
Post by: CougarSE on June 12, 2007, 05:56:56 PM
/thread shiznitting..
Chuck maybe if you posted up a picture of the back of the Tach it would help.  A lot of us haven't seen the back of an old school turbo cluster.
Post by: Chuck W on June 12, 2007, 06:17:16 PM
Quote from: CougarSE;153866
Ok Mr. Poopy ;)
The second pic is with parts removed for clarity.  The post in the middle marked "SIG" is where the input from the coil comes in.
(http://www.turbochuck.com/images/80%20XR-7/83TCtach_1.JPG)
(http://www.turbochuck.com/images/80%20XR-7/83TCtach_3.JPG)
(http://www.turbochuck.com/images/80%20XR-7/83TCtach_2.JPG)
Post by: 84 Fila on June 12, 2007, 06:26:49 PM
I'm intrested in how this turns out!!
Post by: Chuck W on June 12, 2007, 07:26:32 PM
Ok, I'm trying to find some info on that op amp.  I'm thinking maybe if I can figure out the inputs, I may be able to figure out the proper pieces that need to be changed.
I'm not having any luck though.
Post by: Chuck W on June 12, 2007, 07:40:23 PM
More digging.
It appears to be a DIP-14 type OP AMP.  Looking at data sheets, pins 2,3 5,6,9,10,12 and 13 are inputs and 1,7,8 and 14 are the outputs.
PIn #1 is lower right in the pic
Post by: P71 on June 12, 2007, 07:53:16 PM
Hmm, hardwood floors, granite countertops, where do you live again? :hick:
I have NO clue about any of this, but I DO have an 83/84 TC cluster to play with. Maybe Jeff K over on NATO has an idea?
Post by: cougarcragar on June 12, 2007, 08:00:14 PM
Chuck, what will you do with the "Turbo" and "Overboost" LEDs in the cluster?
Quote from: Aerobird Motorsports;153890
It looks like a kitchen table and spray-painted particle board to me. :D
Post by: 84 Fila on June 12, 2007, 08:08:35 PM
IMO I can live with the turbo and overboost lights in the cluster if I have a factory looking Tach. It's alot better then having an aftermarket one that doesn't match the rest of my int. Who ever figures this out, I wana know how to do it
Post by: Chuck W on June 12, 2007, 08:09:16 PM
Quote from: cougarcragar;153891
I'll make the "Overboost" light up whenever an annoying question is asked :D  Not sure yet as they just get an input to say "light"..so I dunno yet.
You are part right...the bench in the garage is painted particle board (there when I moved in), and the wood is a bookshelf top.  I do have some hardwood floors though....just most under carpet :hick:
Post by: Chuck W on June 12, 2007, 08:09:51 PM
Quote from: 84 Fila;153893
OK we know....stop post whoring.....:flame:
Post by: Chuck W on June 12, 2007, 08:13:37 PM
Doing more comparisons to the 79 tach I have.  The "+" and "-" should be the leads to the tach itself.  You can see them on the PCB on the back.
Post by: ipsd on June 12, 2007, 09:44:05 PM
Chuck taking  out the Boost over boost lights should be eazy. Then you can just use those White ones I sent you a while back. You can just take it to photo shop or somthing and take those uneeded labels off.
(http://i152.photobucket.com/albums/s188/ipsd1/Whitefacesinweb.jpg)
Post by: P71 on June 12, 2007, 10:41:39 PM
You know what? I have this really old little column mount tach from my first Nissan truck from ages ago. It's a V8 tach and if you take it apart, on the inside it has this little box on the input wire with a switch that says 4-6-8. I wonder if I could snip that little guy out of there and solder it into the 83/84 TC tach?
Post by: Chuck W on June 12, 2007, 11:34:59 PM
Quote from: Aerobird Motorsports;153935
Well, you'd probably have to defeat what's there to have it work correctly.  Dunno
Post by: P71 on June 13, 2007, 10:23:54 AM
Hrmm... Guess I'll take both apart and post up some pics.
Post by: JeremyB on June 13, 2007, 11:51:06 AM
Circuit manufacturing has come a long way in 25 years. :eek:
Post by: 88turbo on December 29, 2012, 06:34:46 PM
what happened in this situation?  I've been wondering about this mod here recently, has anyone figured out how to do this?
Post by: Chuck W on December 30, 2012, 12:01:18 AM
Quote from: 88turbo;405713
No idea.
I sent a tach off to someone, oh...4 years ago or so, for them to look at it (someone with more electrical circuitry knowledge than I had) and the project just died.  I don't remember who I sent it to. :hick:
Post by: 88turbo on December 30, 2012, 12:30:44 AM
well ! lol wonder if Scott would know what to do with this.
Post by: TOM Renzo on December 30, 2012, 09:39:36 AM
http://www.coolcats.net/modifying/4to8tach.html
Post by: 88turbo on December 30, 2012, 09:57:17 AM
Tom that states that it specifically for 87-88.  The one I have is 83-84.
Post by: Chuck W on December 30, 2012, 09:57:21 AM
Look a little closer, Tom.  We're talking about 83-84...not the 87-88. Not the same thing.
Post by: TOM Renzo on December 30, 2012, 02:04:16 PM
Well thought i would post that SORRY. But from memory a resistor change is what is needed as i remember. Years back a tach had a couple of different resistors for calibration. Honestly i cant think the electronics would be different. pulses are Pulses. Sorry for trying to help!
Post by: TOM Renzo on December 30, 2012, 02:13:39 PM
Ok how about this .
Just trying to help
http://www.v8-ranger.com/tach/tach.php
Post by: jcassity on December 31, 2012, 02:03:15 PM
to be honest, i found this thread interesting, i remember when it started and since i never had a tach, i didnt persue it but did just now check therangerstation.com
to see if there was an udate to thier speedo/tac section, nothing yet.
seems like there is a out of the box solution now per the link tom posted so ,, there it is.
on small equipment there is a tachometer that is a digital display, you simply wrap a wire around the coil lead and it tells you the rpm .  its very tiny only about 1/2'' x 2'' x 1'' but its calibrated with the assumption that 3500rpm is normal operating speed.
here is a link to one at northerntool.com...  http://www.northerntool.com/shop/tools/product_524744_524744
i find these interesting and "could be" much easier to modify,  although they have nothing to do with making the cluster tach more accurate, perhaps the interanls could be modified more easily to do the leg work of sending a signal.  again,, if there is an out of the box solution that works, go with that.
Post by: 88turbo on December 31, 2012, 06:20:04 PM
Thanks guys!  this looks like the solution, how does someone order one of these?
Post by: TOM Renzo on December 31, 2012, 08:49:32 PM
What do you want to order?? The northern one or the one i posted??? I have used many tach adapters over the years. And basically the difference is the pulses per min. The gauge it self should be identical i would imagine. Just a meter movement. But not an electronic engineer. Only thing we do when we install universal tachs is set the switches or select a resistor
Post by: 88turbo on December 31, 2012, 09:45:34 PM
I'm trying to find as much info as I can for a guy that is interested in purchasing the cluster I have. He's wanting it to work with his 5.0 and is also trying to find info on how to do so.  all help is appreciated.
Post by: jcassity on December 31, 2012, 10:19:14 PM
i know right now who has the answer, havent seen him around in so long though,, bondocougar,, and master blaster,, niether have been around for so long but thier legendary work is remembered
Post by: TOM Renzo on January 01, 2013, 09:11:00 AM
Jay it seems to me that all is needed is a TACH module. If memory serves me they are available from many outlets like MALLORY. Basically what you did with the volt meter. I am willing to bet the movement is identical in specks. So just use the movement with a remote transmitter that is calibrated for a V8.
OR buy a tach and use the guts to power the stock tach gauge movement. Another words use the electronics to power the in dash meter movement!!! Bet it will work!
Post by: jcassity on January 01, 2013, 12:42:40 PM
thinking out to loud here,,,
wondering why a tach couldnt be operated off vac pres.  this would eliminate the qty of cylinders and calibration.
Post by: TOM Renzo on January 01, 2013, 01:20:43 PM
Mechanical tachs have been around for years. But never saw a vacuum one????????????
JAY you surprised me on this one. After you went to all that trouble making an AMMETER in to a Voltmeter. A tach should be a piece of cake. Once again buy a tach buttstuffog in nature and use it's internal electronics.  Then wire it to the original movement in the dash. Simple and i think it will work. Or better yet use a V8 ford Tach in place of the 4 Cyl unit. Or just use the V8 electronics to power up the 4 CYL tach movement. Or use a V8 unit and swap the face plate .Not Brain Surgery. just something i think would work!!
Post by: jcassity on January 01, 2013, 02:12:16 PM
I didnt make the ammeter into a volt meter, i gutted the housing and stuffed a volt meter in there.  kept it simple.
the item you posted is turnkey and why bother,, it satisfies the univeral requirement.
the vac tach occures to me evertime i hook up the vac tester  to test and say to myself,, now this guage reads fairly linear with rpm,, why cant it be used to illustrate rpm.
yes i know this isnt 100% true but the vac needle moves,, with R's ,, im sure its already been thought and thrown out as an option.
i love vac operated devices,, keeps things simple
Post by: CoogarXR on January 01, 2013, 03:12:46 PM
Would two cars with two different engines (different displacement, or even different mileage on the same engine type) produce the same measure of vacuum at the same RPM? Probably not. That's probably why there's no vacuum tach. You'd have to calibrate it for every engine. Then probably recalibrate it as the engine ages. Whereas an electrical pulse is a cam rotation on every engine.
If we're reinventing the wheel, and you want true universal tachs, we should measure from the crank sensor pulses. One blip, one rotation, regardless of cylinders. I know, most older cars don't have a crank sensor...
Post by: Beau on January 01, 2013, 04:19:35 PM
Easy enough to get your signal...run a wire to the coil, positive side. Green and white wire. On my cars, I've just popped the pin out of the connector, and added the new wire to it, then reinstalled it into the connector
Post by: softtouch on January 01, 2013, 04:59:42 PM
I don't want to go back to vacuum windshield wipers. They were a pain.
They would stall when you stepped on the gas and go like crazy when you got off the gas.
You wound up adjusting your driving habits to what the wipers wanted you to do.
Post by: TOM Renzo on January 01, 2013, 05:02:22 PM
Coils Positive side  SORRY CHARLIE NO PULSES THERE.
Post by: Thunder Chicken on January 01, 2013, 07:34:08 PM
A Vacuum tach wouldn't work because vacuum is more dependent on engine load than it is on RPM. For example there is very little vacuum at WOT, regardless of engine speed. There is very high vacuum at closed throttle as well, both at idle and when you let off on the gas. Vacuum could be (and has been) used as an economy gauge. Lower vacuum (IE closer to atmospheric pressure) generally equals higher economy. This is why "highway" gears provide better economy - larger throttle opening and low RPM for a given speed gives better fuel economy versus nearly closed throttle at high RPM.
Tom: First off, get your panties out of a bunch and learn to accept when somebody points out a mistake you've made. We know you didn't purposefully try to send anyone astray here, and nobody is shoving bamboo shoots under your fingernails, so no need to act like they are. Second: A pulse most certainly is not a pulse. Pulses vary in strength (voltage), frequency (hertz) and duration (milliseconds). The only one of these three variations that a tach is concerned with is frequency, which changes with engine cylinder count. The more cylinders, the more pulses per second for a given engine speed. No resistor change on the input side of the tachometer can correct for this.
As for resistors: When you replace a resistor in a tach to calibrate it, you are changing the resistance in the part of the circuit that actually moves the needle, not the part of the circuit that counts revs. A tach is basically a primitive digital-to-buttstuffogue converter (DAC). It converts the digital signal of the coil to an buttstuffogue signal that moves a needle. It converts a digital count (how many pulses per second) into an buttstuffogue signal (how much voltage). Higher counts convert to higher voltages, which moves the needle higher. Changing a resistor to recalibrate it merely changes the amount the needle moves for a given signal from the DAC. The DAC still puts out the exact same signal to the needle, but a resistor changes how much of that signal the needle sees. In very basic terms, let's say that you have a 4-cylinder car. A 4-cylinder fires a spark plug every 180 degrees of crankshaft revolution.  This means there are two pulses for every full revolution of the crank. The tach's internal DAC sees two pulses per revolution, but does not know how many revolutions are happening, it's simply calibrated for a certain number of pulses over a certain amount of time, and puts out , say, a 3 volt signal at 2000 RPM. That three volt signal causes the buttstuffogue needle to move to a certain position, which is marked "2000" on the face. Installing an 8-cylinder engine doubles the number of pulses per minute (A V8 fires a plug every 90 degrees of crank revolution, so 4 pulses per revolution). The digital side of the tach would now see twice as many pulses over a given time. Since it does not know how many revolutions are happening (it merely counts pulses per second) it "assumes" the same engine is installed but spinning twice as fast. It puts out, say, 6 volts now, which shows 4000 RPM when the engine is actually only spinning at 2k. The key is to intercept the signal between the DAC and the buttstuffogue needle and change it so that it shows actual engine speed (IE to reduce the 6 volts down to 3, so that when the engine is spinning at 2k RPM the needle only shows 2K RPM). Since it's an buttstuffogue signal the easiest way to do this is a resistor change. The problem is finding which resistor on that circuit board, then using trial-and-error to determine the correct value. This is how the 87-88 style tachs were "cracked".
You might be able to find the key resistor in the 83-84 style if you can trace the circuits back from the buttstuffogue needle. You might even be able to calibrate it yourself by installing a variable resistor in series between the tach's circuit board and the actual needle, but this would require the use of a signal generator to simulate the engine's output while tuning. To do this you'd need to set the signal generator to a certain frequency (say 20,000 pulses per minute, or 333 pulses per second, or 333 Hz, which would be equal to 5000 RPM on a V8) and then adjust your variable resistor so that the needle shows 5000 RPM. Since this circuit very likely wouldn't be "linear" (IE the required resistor value might vary at different tach readings) you'd be advised to choose something close to redline to calibrate to, since this is the most important end of the tach...
Post by: jcassity on January 02, 2013, 01:54:26 AM
thinking out loud again,,
wonder what a split core CT would do for information gathering placed on the coil wire.  Split core ct's are not all that expensive either especailly the size we are talking, Square D makes several we use for whole facility or individual circuit current monitoring, i know exactly whats happening inside them, never occured to me what they would do around a coil wire.  they are passive as well, thats a plus.
i think we got a bunch of idea hampsters around now, its good to think and wonder once in a while, keeps you on your toes.
Post by: TOM Renzo on January 04, 2013, 10:45:30 PM
Ok ladies and gentlemen. I totally know that a series resistor in the Kettering Ignition system wont change the Tachs ability to sort out Pulses. If this bugs you and you need a place to hook up a TACH use the alternator. tach pulses can be obtained their. Other than the hundreds of tachs i have installed over the years they either have a select switch for cylinders or an INTERNAL RESISTOR TO CHOOSE FROM. And or a combination of resistors to alter the tachs cylinder designation. I did not post a series resistor for tach selection on it,s lead gathering info from the coil.
NOTE DIESELS get Tach pulsed from the alternator. Imagine that!!!
Electronic tachometers work by counting pulses.
http://www.bakerelectronix.com/products_tsd/
This is from FORD!!!
The tach signal is a pulse. The factory pickup spot is pin 4on the computer.  The wire color is a dark green/yellow for 88-91 cars.
Altering the tach for different cylinders may include a condenser and or a resistor or a combination of both. I am not an electronic engineer. I have a double masters in mechanical engineering. So i corrected a post!!! And got thunder mad.  I will be available next week for the lynching at a described time as posted by Thunder Chicken . Make the arrangements with him.
Post by: Thunder Chicken on January 05, 2013, 07:28:24 AM
Tom, you know, you don't have to get your panties in a wad every time somebody points out a mistake you've made. You also don't have to go all ape shiznit every time somebody does something a different way than you would have. Just because you don't understand something does not make it wrong (for an example of you not understanding something that is really quite simple, I refer you to your quote of "Being as you designed a system that i am getting a headache trying to figure it out" from Scott's original relay thread - it's two relays, Tom, it's not rocket science). I'm getting very tired of seeing you go off the deep end in just about every technical thread on this forum. Judging by the number of complaints I get about you via PM I'd say I'm not alone. I actually refrained from tearing a strip off you in that thread (and pointing out how absolutely wrong you are with your silly "redundant relay" setup - I don't care how you actually wire them, if they are wired as you've drawn them they will not work) because A) You'd already shiznittied up the thread enough and B) I just don't have the time to go toe to toe with you in nearly every God-ed thread on this forum (regrettably I also don't have the time to deal with all the complaints against you on an individual basis).
Enough is enough. Unfortunately for you I have the keys to this place, so to speak. Consider this a warning. Keep on trashing threads with your "I'm right, everybody else is wrong" attitude and you're gone. There will be no more warning, you'll just try to log in one day and be gone.
