Technical => Body/Appearance/Interior => Topic started by: 88sportcoupe on June 10, 2007, 09:01:12 PM
Title: Rear Window Trim
Post by: 88sportcoupe on June 10, 2007, 09:01:12 PM
Well my trim on my rear "windshield" is screwed up, and most of it is missing, I was reading on Nato messageboard and saw a couple threads about how some 88 cars got a "one-piece" trim that is attached to the window. Well i think that is what i have here and my rear window right now is held down from falling out by silicone in the top corners.
I am hoping someone could help me out with a way to replace the trim without having to change the window.
Post by: P71 on June 10, 2007, 09:09:45 PM
That's the multi-piece metal trim. Call up a local glass installer (CarLite, SafeLite, whatever) and they should have the 1-piece rear molding. It's jut universal stuff that's cut-to-fit.
Post by: 88sportcoupe on June 10, 2007, 09:18:39 PM
Are you sure? I know you have seen more than i have but it is broken in the pics and at the top there was a plastic piece that was all warped. I know it is different than what was on the TC at the JY cause i tried to pry it off the TC and it kept bending where the clips were, when i pulled it off mine it just keeps breaking every 6-8 inches. It looks like it goes under the window, and i havent seen ANY clips on the rear window except on the bottom by the trunk.
How does the universal stuff look after installed? How is it installed?
Post by: P71 on June 10, 2007, 11:26:29 PM
Your pics make it kind of hard to tell what yours has exactly. Honestly now that I've looked at it, yours looks like the universal stuff.
