Marketplace => T-Bird/Cougar Parts & Cars WANTED => Topic started by: revnkvn on January 31, 2005, 09:55:32 PM
Title: Fender molding....87 XR7
Post by: revnkvn on January 31, 2005, 09:55:32 PM
Looking for a molding behind the front bumper, but in front of the front wheel. This molding may also have the cornering lamp in them.
  i need a solid PASS. side,but if I can get both panels with the cornering lamps, I'll take that also.
  E-mail me at bigblock6764@yahoo.com
                Thanks alot!        Kevin Fry
Title: Re: Fender molding....87 XR7
Post by: Cougars 2 go on February 01, 2005, 08:35:58 PM
Quote from: revnkvn
If you need one because the mounting posts on yours broke where the plastic weld is, you may be able to use short strand fiberglass to "glue" the mounting posts back on to the piece and then mount it back on your car.  That's what I did.  I tried JB Weld first but it didn't hold.  Fiberglass did the trick for me.
Post by: Master_xzavior on February 04, 2005, 07:26:36 PM
one of my molding pieces has a real short fat screw in it that doesnt go all the way through it threaded into the circle part left from the mounting post since it was gone I had to do something but it looks great and unless you look at the inside of the panel where the nuts actually hold the piece on you cant tell its there. didnt think about glueing it back together maybe next time it happens I will though.
