General => Lounge => Topic started by: jcassity on June 06, 2007, 10:21:17 AM
Title: EVTM lottery CD give away
Post by: jcassity on June 06, 2007, 10:21:17 AM
10oct08- This loto is open again as of 10oct08 for folks who cant download the PhotoBucket evtm and anyone else. Go to the last page and partite in the next question.
This is going to be fun. Ive decided to loto off the 1987 evtm on cd as the bootie!
Go to the end last page of this topic and scroll backwards to find the latest question.
Rules,, ill ask a Fox related question (suject to change) and the first correct reply will win a copy of the EVTM. You must back up your answer with some rational dgree of knowledge or database.
if you have already won,, dont answer, but you can assist others by helping a little.
If the time stamps are the same within the replies,, there will be a double winner If i see an answer not quite correct but the closest, it will be pointed out but no winnings will be awarded I will decide who won, that way its kept fun. Loto held,, randon but hopefully after each and every correct response. Ill keep this loto isolated to this thread only so it will continue on unless i am told otherwise.
now on to the fun..........
Thunderchicken investigated the Trip minder installation into a car that did not come with the Trip minder itself.
According to him,(to which i consider the authority on this topic) what wiring mods need to be done for installation into your car if it was designed within the years trip minder was an option?
Post by: Thunder Chicken on June 06, 2007, 11:49:04 AM
OOOH! OOOH! I know the answer! :hick:
Joking apart, I'll disqualify myself. I already have the 1987 EVTM :D
Post by: 84 Fila on June 06, 2007, 11:54:52 AM
PARTS NEEDED:
Functional Tripminder computer with its connector and wiring Fine grit (around 800) Sandpaper 4mm deep socket for a 1/4” drive ratchet A good cutting and crimping tool Tap splices (2) and Butt connectors (6-7) Extra 14 or 16 gauge wire, two different colors preferred Electrical and Vacuum Trouble Shooting Manual (EVTM) for your vehicle (HIGHLY recommended)
Cut the Tripminder loose with its connector on the back intact. Take a look at the wires on the back of the Tripminder. Notice how there are more pins in the harness than there are wires. Here are what the pins correlate to and their wire colors.
Pin 1: EMPTY Pin 2: EMPTY Pin 3: Ignition Power (light blue/black stripe) Pin 4: Dimmer (light blue/red stripe) Pin 5: Power (light green/yellow stripe) Pin 6: Fuel Flow Input (light blue/pink stripe) Pin 7: Ground (black) Pin 8: Speed Input (dark green/white stripe) Pin 9: Ground (black) NOTE: the wire colors may differ slightly from year to year. NOTE: Pin 7 and Pin 9 may or may not be connected together at the factory
Once you acquired a junkyard Tripminder, it would be wise to test it outside the car to verify it works. Hook up power, ground, and ignition. If the unit works you will see “12:00 RESET” on the display. Try the buttons. If some or all of the buttons don’t work, do not worry.
This is how you fix the buttons: take apart the computer (when turned off, in a static electricity free area) and clean the metal contacts of the buttons with that sandpaper. The Tripminder comes apart pretty quickly. A flathead screwdriver inserted into the four slots on the sides will separate the case into a front and a back side. Pull the back from the front and unfold the computer’s circuit boards. It unfolds like an accordion: I never said this was a well-engineered computer!
The last board is bolted to the front of the Tripminder via four 4mm bolts. Unbolt these and pull the circuit board free of the Tripminder. You will now see the other side of the circuit board: seven little push buttons (metal, not the plastic ones) that surround the vacuum fluorescent display of the Tripminder. Fold a small piece of the sand paper (sand on both the top and bottom) and GENTLY slide it between each of the seven buttons. You should be sliding the paper between the metal you see and the circuit board. Push down on the button and move the sandpaper up and down a few times. This will clean both sides and remove all corrosion/oxidation from the contacts. When this is done blow off any sand or residue with compressed air or your mouth. Reverse the disassembly process. Congratulations: you now have a brand new Tripminder computer!
Now take a look at the standard (what is currently in your car) digital clock’s wiring. When you compare this to the Tripminder you will see that you already have 5 of the 7 wires given to you! Who-hoo!
Pin 1: Ground (black) Pin 2: Power (light green/yellow stripe) Pin 3: Ignition (Light blue/Pink) Pin 4: Dimmer (Brown) NOTE: the wire colors may differ slightly from year to year.
You will need to remove the wires from your car's clock harness and splice them into the Tripminder's harness. Your brown wire (pin 4) goes to the Tripminder's brown wire (pin 4). Your black wire (pin 1) goes to the Tripminder's black (pin 9) wire. Your light blue/pink wire (pin 3) goes to the Tripminder's wire in pin 3 (colors may vary). Lastly, your light green/yellow wire (pin 2) goes to the Tripminder's light green/yellow (pin 5).
So yes, there are only two extra wires needed: all the others are there with the factory clock. One is for the fuel flow, which you will have to splice from PIN #34 at the EEC-IV engine computer. The other is the input wire for the speedometer.
For the speed input, you will have to remove the gauge cluster and disconnect its wiring harness. This is where the Ford EVTM manual will come in handy. Judging from my EVTM, the signal you want is located in circuit #150, remember its a dark green/white stripe wire. The buttstuffog performance cluster (XR-7 models) has the speed input at PIN #18. The regular cluster supposedly has it at PIN#3. Double check all wires and circuits to see if you are getting a pure speed signal from the engine computer. My 1988 model XR-7 with buttstuffog gauges had it in PIN #18 and there were two dark green/white striped wires feeding it. Your car MAY vary from this. Once you are sure you have found the right circuit, use a tap splice and connect a length of wire to this circuit. Run the wire back to the Tripminder and connect it to PIN #8 on the Tripminder. You now have speed information to your computer.
The fuel flow input works on the same principle. From what I have seen, all Ford products using EEC-IV computers have a “fuel flow” signal that comes from PIN#34 of the EEC computer. Judging by my car and many Lincoln Mark VII LSC owners, anyone that has done the Mass-air conversion should have no problem getting the signal either! Just remove the passenger side kick panel, slide out the computer and look for PIN#34 and a light blue/pink striped wire coming from it! Use the tap splice again and connect this wire to the Tripminder’s PIN#6. Route the wire between the glove box and the blower motor. I would suggest using a very long wire and tucking the extra length away, just in case you have to replace the blower and need that wire out of your way.
[/I][/B] I used coolcats. Thanks Eric
Post by: jcassity on June 06, 2007, 02:34:35 PM
well,, apparently thunderchicken,, You have to correct me on this.
The last notes i took on your Trip minder project, You said it was "PLUG AND PLAY"
hold on fila:D
Post by: 84 Fila on June 06, 2007, 03:03:08 PM
Sure thing Scott. I'll be here
Post by: Thunder Chicken on June 06, 2007, 04:01:20 PM
It is, apparently and typically of Ford, plug-and-play on some vehicles, but not on others. Mine was plug-and-play, but some people have had to run the wire to pin 34, and some don't have the jumper harness between the clock and main harness. Some quotes from the original thread:
Quote from: Thunder Chicken
it seems that on some cars, even though the fuel flow wire is in the clock harness, at some point it is not connected to the ECU. It's a touch and go kind of thing - my car is a base 5.0 car and had the wire connected while the person that wrote me had a loaded '88 XR7 and the wire was not connected. They ran a jumper and all was fine. The ECU is behind the right kick panel.
The trip minder will work with any EEC-IV and is not calibrated by engine - it receives a signal from the ECU telling it the fuel flow rate, and it combines that rate with the time and VSS signals to provide economy, average fuel economy and fuel used numbers. It's essentially a calculator
Quote from: CougarSE
I had my dash panel off today and still couldn't find the connector. its just not there. The wires for the clock go strait into the main harness
Quote from: cougarman
Just an FYI, I stripped out an 88 TC yesterday, and it didn't have the connector on the end of the clock harness. The clock wires ran directly into the main harness, so it seems the harnesses are hit and miss on these cars. :crazy:
Quote from: Tbird232ci
im also finding out that the TC's didnt have a signal from Pin34 to the clock harness, only the Base/LX/LS/GS cars did
Just had this PM'd to me. Then person that sent it isn't 100% sure about all T-Birds/Cougars, but in their own experience this is what they have discovered:
Quote: In cars with the buttstuffogue clock the power wire for the 194 bulb is in place of the fuel flow wire, so cars that had the buttstuffogue clock DIDNT get the fuel flow wire at the clock harness. I pulled my tripminder one day, and was testing the wires for voltage and identifying each wire. I turned the lights on, and got 12ish volts at the fuel flow wire, lights off, 0
according to the NATO boys, in the TC's, the fuel flow wire goes up to an 8 pin connector on the firewall, which i believe is for the cruise control, i tried to use the EVTM i have on disk, and its a bit tricky, but i also traced it there, and found it on the connector actually in the car So as you can see, it really ishiznit-and-miss when it comes to installing a tripminder. As with many other features in these cars, not all cars had the same wiring, and there seems to be no definitive pattern (having an LX, for example, does not guarantee you the harness). In some cars it's plug & play, in some there is no clock harness connector, in some the clock harness connector is there but the fuel flow wire is not (or is not connected to the fuel flow input on the computer), and in some that fuel flow wire is actually a backlighting wire for the buttstuffogue clock.
Regardless, I still think of this as a very easy modification, much easier than, say, installing an aftermarket stereo. All of the circuits required to make it work are already in all 80's fuel injected Fords, but in some cars you have to go looking for them. Most of the circuits required to make the tripminder to work will be in the dash by the clock, whether you have the connector or not. The tripminder needs:
Power (constant 12V) Accessory (switched 12V) Inst Cluster lighting (switched on with dash lights) Ground
All of the above are at the clock, whether you've got the removable harness or not. It also needs:
VSS input (from speedometer) Fuel flow input (from pin 34 at the EEC-IV computer)
So if you get a tripminder with the connector still attached, at the most you'll have to run two wires, one to the cluster and one to the computer. You can find all of the others at your existing clock, so if you have to, you can cut the factory clock connector off and splice on the tripminder connector.
Post by: CougarSE on June 06, 2007, 04:15:23 PM
Wow that was a long time ago...
About a year ago I thought I had the whole thing figured out. But I've since forgotten all about the tripminders.
Post by: jcassity on June 06, 2007, 09:42:21 PM
OK
and the winner is,,,,,,,,,[SIZE="7"][COLOR="Red"]84 fila!!!!!!:D[/COLOR][/SIZE]
email me with your addy and ill drop your cd in the mail,,or call me.
my email is revised@brier.net
Congrads!!!!
Post by: jcassity on June 06, 2007, 09:50:19 PM
ok,, on to the next loto question,,,,:D
In my honest opinion, a memeber of this board has done the most unique engine swap that i can think of to date. No one here has done this swap but him and its a 3.8 SC. If i am incorrect on this then correct me please but i cant think of anyone but him. This car is a one of a kind.
What is this member's user name?
Post by: Thunder Chicken on June 06, 2007, 10:30:02 PM
Same prize? 'Cuz I know this one too :hick:
Post by: nirvanagod on June 06, 2007, 10:33:19 PM
Quote from: jcassity;152335
Prolly Spazpuppies.
Post by: Cougar8775 on June 06, 2007, 11:21:44 PM
there is spazpuppies and CougarSE
Post by: 84 Fila on June 06, 2007, 11:52:35 PM
Claude aka CougarSE
Post by: Ifixyawata on June 07, 2007, 01:15:39 AM
Nope, it's Spazzpuppies. I don't think Claude ever went through with it.
Post by: jcassity on June 07, 2007, 02:33:13 AM
Quote from: nirvanagod;152342
Prolly Spazpuppies.
you prolly be CORRECT and the winner is,,,,,,,,,,,,,,,,,,,[COLOR="Red"][SIZE="7"]NIRVANAGOD[/SIZE][/COLOR]
email me,, revised@brier.net with addy and ill get er in the mail
Post by: nirvanagod on June 07, 2007, 09:38:20 AM
Heh, I'll allow someone else to have it. I don't exactly have a need for it! Prolly shouldn't have answered :hick: :beatyoass: !
Post by: jcassity on June 08, 2007, 01:17:02 AM
moving right along,,,,,,,,,
NEXT loto question
on the 3.8cfi , which fuel line is considered your fuel delivery line? Remember all views or references are always and forever described while sitting in the driver seat.
:D
Post by: Ifixyawata on June 08, 2007, 01:27:06 AM
The one that comes into the rear center of the CFI body? As I recall the return leaves at an angle toward the right (from sitting in car). Also, I think that one's the bigger of the two, plus it's right inline with the FPR.
Post by: jcassity on June 08, 2007, 01:49:02 AM
Quote from: Ifixyawata;152566
which one is the feed,,,? i cant make heads or tails on your reply. It looks like your talking about both of them. no cfi fuel line came into the rear center.
im looking for a one or two word answer based on the hint. ,, or just be more clear but dont mention the line that has nothing to do with the question.
Post by: Ifixyawata on June 08, 2007, 01:52:14 AM
Sorry, meant to say the feed is the one directly at the rear center of the CFI unit. The return is the one off to the side. I might have 'em backwards, I didn't even go out and look to cheat.
Post by: 84 Fila on June 08, 2007, 01:52:31 AM
Driver side is feed. Passanger side is the return IIRC
Post by: 84 Fila on June 08, 2007, 01:53:19 AM
I'm holding mine lookin at it. I'm guessing though
Post by: Ifixyawata on June 08, 2007, 02:14:48 AM
Alright, let me rephrase. The FEED is more toward the center than the Return. The Feed is actually to the RIGHT of the return. The return comes off on the LEFT side of the CFI, from sitting in the car.
Post by: jcassity on June 08, 2007, 02:24:40 AM
Quote from: 84 Fila;152571
nope,,, :D
Post by: 84 Fila on June 08, 2007, 02:25:28 AM
Brian FTW!!! I had it bass-ackwards
Post by: jcassity on June 08, 2007, 02:27:15 AM
Quote from: Ifixyawata;152576
yep,, BINGO,,
Answer,,,>Passanger side and the winner is [COLOR="Red"][SIZE="7"]Ifixyawata!![/SIZE][/COLOR]
pm an addy or email me revised at brier.net
Its interesting,, three buckeyes in a row,, yall must be some smart people.
Post by: 84 Fila on June 08, 2007, 02:28:23 AM
2 of us withen 20 miles
Post by: jcassity on June 08, 2007, 02:35:31 AM
if you already won,, you can mess with people all you want but dont answer.,,its not fair,,:beatyoass: :D
ok
next question
hard one,, might have to pull an abe lincoln and do some reading.
On a CFI setup, its easy as hell to get a gallon of gas if you need cut the grass ect. all you do is unhook the passanger side fuel line and stick it up to your gas can. Next you would turn on your key but only a spurt of fuel would come out. :mad: to make the fuel pump run as long as you want,, WHICH WIRE DO YOU GROUND ON THE EEC TEST CONNECTOR TO MAKE THE FUEL PUMP RUN?
Post by: 84 Fila on June 08, 2007, 02:36:48 AM
I know!!!!!!!!!!!! I know!!!!!!!!!!!!!! I could have won 2/3:flip: ;)
Post by: 84 Fila on June 08, 2007, 02:42:58 AM
Here is the test connector if anyone wants to take a guess (http://i140.photobucket.com/albums/r9/84fila/000_2320-1.jpg)
Post by: jcassity on June 08, 2007, 03:44:39 AM
did that come out of your car? lol, your gonna confuse everyone
Post by: Sduneman3 on June 08, 2007, 03:46:30 AM
The red wire?
Post by: jcassity on June 08, 2007, 03:55:20 AM
nope,, but you can keep guessing.
Hey fila go delete that pic,,,,,,,, :evilgrin:
Post by: 84 Fila on June 08, 2007, 05:47:39 AM
C'mon scott, give um a chance:flame:
Yeah it is out of my car, in one peice. That pic is in my room, in the box where my once nice CFI lives now.
Post by: Cougar8775 on June 08, 2007, 08:17:18 AM
i know this one its the tan wire
Post by: jcassity on June 08, 2007, 10:46:53 AM
Quote from: Cougar8775;152615
NOPE,, your answer would cause someone to hose up big time.
the i suppose they would hand you an "ID I0 t" form to fill out L )
Post by: 88sportcoupe on June 08, 2007, 11:08:27 AM
On my car it is a redish/orange with a green stripe.
Post by: jcassity on June 08, 2007, 05:21:53 PM
Quote from: 88sportcoupe;152639
are you sure?
still not the corret answer.
Post by: JeremyB on June 08, 2007, 05:33:57 PM
Quote from: jcassity;152585
That one is too easy. :p
I ran my Cougar that way for ~8 weeks after my computer semi-fried its internals.
Post by: jcassity on June 08, 2007, 07:02:03 PM
Quote from: JeremyB;152728
as i thought, it would be kind of hard for most people who dont have wiring diagrams.
so,, in a way its hard. This is kind of a test fo rthe knowledge base.
so far,, there is a tie for the closest answer,,,,
"redish/orange with a green stripe" and "the tan wire"
Post by: 84 Fila on June 08, 2007, 07:06:37 PM
Can I tell um?
Post by: 88sportcoupe on June 08, 2007, 07:28:00 PM
I am not sure of the color.
Well looking at the connector it would be the terminal on the right bottom close to the 4 terminals. Though i am looking at my 88 Sport so it could be different on the older cars.
Post by: 84 Fila on June 08, 2007, 07:30:13 PM
*HINT* the color I posted on the pic isn't the best pic in the world, but the answer is there if you look hard enough. Also remember that colors fade over time. A red can turn to almost a pink, and grey to white.
Post by: 88sportcoupe on June 08, 2007, 08:00:58 PM
Well in that pic it looks like it is dirty white.
Here:
Post by: Sick88Tbird on June 08, 2007, 08:47:57 PM
Mine is a tanish/brownish color with a light green tracer.
Post by: jcassity on June 08, 2007, 09:04:27 PM
Quote from: Sick88Tbird;152763
and the winner is,,,,,,[COLOR="Red"][SIZE="7"]SICK88TBIRD!![/SIZE][/COLOR]
answer: Tan/light greeen
pm me with an addy or email at revised@brier.net
Post by: Sick88Tbird on June 08, 2007, 09:09:05 PM
w00t!!!
Post by: jcassity on June 08, 2007, 09:40:03 PM
and now back to the loto,,,,,,
todays new question is........
what one word describes a situation in the combustion chamber where all or neally all fuel is burnt off. It is when your air and fuel ratio are nearly perfect and is so very important in the EFI engines.
Post by: 88sportcoupe on June 08, 2007, 09:48:09 PM
Not sure i understand the question but here is my answer if i understand it.
Stoichiometric ????
Post by: jcassity on June 08, 2007, 09:57:38 PM
Quote from: 88sportcoupe;152787
Stoichiometric ????
BINGO!!! another winner,,,,,,,,,,[COLOR="Red"][SIZE="7"]88sportcoupe[/SIZE][/COLOR]
pm with an addy or email me at revised@brier.net
Post by: 84 Fila on June 08, 2007, 10:17:31 PM
Next question!! Can we play for fun, then give the win away to someone else Scott? I kinda feel smart knowing this
Post by: JeremyB on June 08, 2007, 10:21:41 PM
Scott's weekly trivia!
Post by: jcassity on June 09, 2007, 10:49:48 AM
this question is for 84fila only,,,
What locations have we found the power lock buttons to reside in either the cougar or tbird from 1983 to 1988.
Post by: 84 Fila on June 09, 2007, 11:02:08 AM
In the door? I have mine near the door handle. 85+ in in the arm rest right?
Post by: jcassity on June 09, 2007, 11:52:43 AM
:D
Quote from: 84 Fila;152866
yep,,,
Post by: 84 Fila on June 09, 2007, 11:53:46 AM
So... what did I win this time;)
Post by: CougarSE on June 09, 2007, 11:57:21 AM
Post by: jcassity on June 09, 2007, 12:00:29 PM
now on to the loto:D
If i had transmission fluid dripping from the passanger side of my AOD transmission, and the pan is not leaking, what would be the first part you would think to replace? Why?
Post by: jcassity on June 09, 2007, 12:11:19 PM
That pic shows the american flag. My boys uniforms for Tae Kwon-DO has the flag positioned just the same.
IT's the wrong badge !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
the flag nees to be on the other way around. That is a left arm flag badge,, i hope the boyscouts know this cause its very important to apply badges correctly. Imagine there was a staff attached to that flag,, and you were holding that staff, you are in "RETREAT" mode.
me off.:mad:
The orientation of that flag promtes the fact that we are moving "backwards", not forward in battle. The badge needs to face "FORWARD" in your battle direction as you would expect of a brave soldier.
attention to detail doesnt matter anymore,, oh well.
Post by: JeremyB on June 09, 2007, 12:53:00 PM
Scott, his uniform is worn correctly (at least wrt to the flag). [Source (http://"http://en.wikipedia.org/wiki/Uniform_and_insignia_of_the_Boy_Scouts_of_America#Insignia_2")]
The only people allowed to wear a "backwards" flag on their right sleeve are soldiers. This is because they're the only ones that will be going to battle.
Post by: Cougar8775 on June 09, 2007, 03:22:14 PM
ok now to the question at hand.... I would replace the trans cooler lines ether due to rust, Or one of the fittings failing.
Post by: jcassity on June 09, 2007, 11:13:10 PM
Quote from: Cougar8775;152931
and a new winner!!!!!!!!!!!!!!!!![COLOR="Red"][SIZE="7"]Cougar8775[/SIZE][/COLOR]second times a charm man!!
pm or email me revised@brier.net
Congrads:D
Post by: 84 Fila on June 09, 2007, 11:16:18 PM
Next brain buster:evilgrin:
Post by: jcassity on June 09, 2007, 11:20:55 PM
and now,, a new question that may stump a few of you.
what other car did the ford EXP share body styles with and what does it have in common with this site?
Post by: 84 Fila on June 09, 2007, 11:27:51 PM
Merkur X4ti?? And that is has the 2.3T also?
Post by: ZondaC12 on June 09, 2007, 11:32:34 PM
Mercury LN7
Mikey--the XR4Ti was a european ford, brought over here, modified to fit our safety and emissions standards, and rebadged under a made-up "brand" if you could call it that. and people wonder why it sold badly. terrible tragedy.
Post by: jcassity on June 09, 2007, 11:43:10 PM
Quote from: 84 Fila;153043
nope:evilgrin:
Post by: jcassity on June 09, 2007, 11:45:09 PM
Quote from: ZondaC12;153045
Mercury LN7
wholey correct on your comparrison of the EXP to the LN7
however,,
none of the two have any relationship to this site,,,,,,,,so,,,,,,,,,
wrong answer.
Post by: Cougars 2 go on June 09, 2007, 11:57:55 PM
Quote from: jcassity;153051
however,,
wrong answer.
Relationship to this site or the cars to which this site pertains?
Post by: jcassity on June 10, 2007, 12:23:23 AM
i goofed,, i swear i did not mean to but it was bound to happen sooner or later,, after a nice hot shower,, and getting the days yard work off me , it occured just in an instant that i made a mistake.
here is the question as it should be,, and with a hint ,,kinda,,
several years back, what other car did the ford Escort share body styles with and what does it have in common with this site?
:D this may be a decent hint found on an 84.
Post by: 88sportcoupe on June 10, 2007, 12:41:56 AM
Edit: I already won so i will withdraw my answer
Post by: jcassity on June 10, 2007, 12:51:38 AM
interesting badge there, isnt it?:evilgrin:
Post by: 88sportcoupe on June 10, 2007, 01:04:19 AM
Just verifying my answer to myself with google and I just found the exact same picture (http://"http://memimage.cardomain.net/member_images/7/web/211000-211999/211593_34.jpg").
Post by: ZondaC12 on June 10, 2007, 01:09:38 AM
ugh. makin' me work huh!!!??? :hick:
Fine. Lynx! now gimmie my big red text!
Post by: jcassity on June 10, 2007, 02:30:39 AM
Quote from: ZondaC12;153074
WOOOOOOTTTTT and the winner is,,,,,,,,[COLOR="Red"][SIZE="7"][FONT="Comic Sans MS"]ZondaC12[/FONT][/SIZE][/COLOR] but you forgot part two of my question to which ill cut you slack on. It has the badge in common with coolcats , cougars ect.,,:D
:cougarsmily: congrads!!!!!!!!!
pm me with your addy or email me at revised@brier.net
scott
Post by: jcassity on June 10, 2007, 08:58:03 AM
now on to the next question,,,,,,,,,,
i have 20 ready to go cd's wating for winners so thats when ill stop.
question, Of all the fox body cars covered on this site, which engine got an adjustable fuel presure regulator stock from the factory?
Post by: 84 Fila on June 10, 2007, 11:47:22 AM
Any of the CFI cars. It's the round thing on top of the CFI. You take the little cover off (about the size of a dime) and you can adjust the fuel pressure.
Post by: jcassity on June 10, 2007, 11:42:09 PM
Quote from: 84 Fila;153136
correct,,,,,,,,,, but why did you answer?
your already a winner:beatyoass: now someone else could have won but cant on this question,,which was rather easy if you ask me.
Post by: 84 Fila on June 10, 2007, 11:46:51 PM
Totally forgot man..... I'll give the win to anyone else who gets it. I'll even delete the comment. Sorry Scott
Post by: 84 Fila on June 10, 2007, 11:47:26 PM
Gone!
Post by: jcassity on June 11, 2007, 12:04:14 AM
now on to another question for a free CD of the 1987 EVTM.
This is a research type question,,,,
In my DIY link above my sig,, according to member "cougarcrager".
Which vehicle offers a perfect match for door weather stipping on our cars both cougars and tbirds?
Post by: stuntmannick on June 11, 2007, 12:32:01 AM
'92 Mercury Topaz
Post by: jcassity on June 11, 2007, 12:36:51 AM
Quote from: stuntmannick;153331
'92 Mercury Topaz
you da man!!! and the winner is,,,,,,,,,,[COLOR="Red"][SIZE="7"]stuntmannick[/SIZE][/COLOR]
PM me with an addy or email me at revised@brier.net.
ill get your cd out asap.
scott
*******BTW there are two winners who have not gotten me thier address yet,,,, they are......
Cougar8775
ZondaC12
Post by: jcassity on June 11, 2007, 07:51:00 AM
no to the next loto question for a cd ot the 1987' EVTM (Electrical and Vacuum Troubleshooting Manual)
You engine idle is rather high and you cant figure out why. Its not really too much to bother you but it exceeds specs.
With you key on only (KOEO), Someone on here told you to check and make sure you have less than 1volt DC on your green wire and about 4.6volts DC at wide open throttle.
What part are you checking on your engine?
Post by: Quietleaf on June 11, 2007, 08:04:21 PM
(shot in the dark)
throttle position sensor?
Post by: 84 Fila on June 11, 2007, 08:11:32 PM
Just got my EVTM toay scott, but left the package in my freinds car. Thanks for the win man!!!
Post by: SLEEPER T-BIRD 87 on June 11, 2007, 09:11:52 PM
Quote from: Quietleaf;153540
(shot in the dark)
yup:D
Post by: 84 Fila on June 11, 2007, 09:14:06 PM
Correcto-mundo!!!
Post by: jcassity on June 11, 2007, 10:14:46 PM
(shot in the dark)
and your shot in the dark shines bright!!!!!
and the winner is,,,,,,,,,,,[COLOR="black"][COLOR="Red"][SIZE="7"][FONT="Comic Sans MS"]Quietleaf[/FONT][/SIZE][/COLOR][/COLOR]
pm me with your addy or email at revised@brier.net
congrads!!!!!!!!!!!
Post by: jcassity on June 11, 2007, 10:19:10 PM
and now back to the lotto,,, unrelated to this site,,,or a farking car:hick:
according to my 11 year old,, he would like to propose a quesiton:evilgrin:
What is the 4th state of Matter? 1=solid 2=liquid 3=gas 4=?
Title: plasma
Post by: Sduneman3 on June 11, 2007, 10:20:22 PM
it's plasma
Post by: 84 Fila on June 11, 2007, 10:24:02 PM
I honestly don't have a clue bro?
Post by: SLEEPER T-BIRD 87 on June 11, 2007, 10:26:48 PM
plasma is considered by some to be the 4th state of matter by some scientist
Post by: jcassity on June 11, 2007, 10:31:16 PM
Quote from: Sduneman3;153610
it's plasma
holly snits,,, thats a record response,,:shakeass: :bowdown:
and the winner is,,,[COLOR="Red"][SIZE="7"]sduneman[/SIZE][/COLOR]
pm with your addy or email me,,,
congrads!!!!!!!!!!!!!!!!
Post by: Sduneman3 on June 11, 2007, 10:32:47 PM
Quote from: jcassity;153619
and the winner is,,,[COLOR="Red"][SIZE="7"]Sduneman3[/SIZE][/COLOR]
Thanks, that's what college chem does for you?!?
Post by: jcassity on June 11, 2007, 10:46:23 PM
and now back to the lotto:D :D
how do you enter the diagnostic test for the digital speedometer?
keep it simple,, just "how do you enter this mode.
Hint,, its on this mesage board somewhere,,:cougarsmily: \ your allowed to cheat in anyway possible as long as you get the answer ,,, getting the answer and posting it here helps spread the word on these topics and how to troubleshoot. SO,,, t'is productive cheating,,grinno
:evilgrin:
Post by: SLEEPER T-BIRD 87 on June 11, 2007, 10:52:22 PM
Hold the Trip Reset button in with the switch in the run posistion
Post by: Hillbilly Deluxe on June 11, 2007, 10:54:57 PM
Hold the Trip Reset button in turn the ign switch to run
Post by: jcassity on June 11, 2007, 10:55:46 PM
Quote from: SLEEPER T-BIRD 87;153635
hummm,,, thinking,,, ;)
Post by: SLEEPER T-BIRD 87 on June 11, 2007, 10:57:23 PM
Quote from: jcassity;153639
:D
Post by: jcassity on June 11, 2007, 10:58:11 PM
ok,, actually,,, and im gonna let it slide:hick:
hold the trip reset button in
then,,,,,,,,,,
turn the key on
but,,,,,,,,,,,,THE WINNER IS [COLOR="Red"][SIZE="7"][FONT="Impact"]SLEEPER T-BIRD 87 [/FONT][/SIZE][/COLOR]
CONGRADS!!:D
wow,, thats three cds going out in the morning,, if you pm me now,, that will make 4
Post by: SLEEPER T-BIRD 87 on June 11, 2007, 10:59:07 PM
Quote from: jcassity;153643
then,,,,,,,,,,
turn the key on
CONGRADS!!:D
lol im dislexic sometimes:toilet:
pm sent
Post by: jcassity on June 11, 2007, 11:01:47 PM
and now back to the LOTTO!!!! kickin a$$ tonight:hick:
what would you expect a tan and black vacuum line to be connected to under the hood of a 3.8L. they are connected to something on one end and something on the other,, Its common that we delete them for personal reasons.
answer with either end and win!!
Post by: daboss351 on June 11, 2007, 11:09:40 PM
im gonna guess something emissions related
Post by: jcassity on June 11, 2007, 11:10:29 PM
Quote from: daboss351;153647
:D got a flashlight,, go take a look,, its likely the same on the mark , 302 ,, 3.8 and most likely the 2.3
Post by: daboss351 on June 11, 2007, 11:12:52 PM
they connect to the smog pump and behind the colant tank?
Post by: 84 Fila on June 11, 2007, 11:14:58 PM
OHHHH, I know. Pick me, Pick me!!! Lol. A hint is it's in his DIY Link IIRC
Post by: jcassity on June 11, 2007, 11:15:21 PM
Quote from: daboss351;153649
SNAP!!!
and the winner is [COLOR="Red"][SIZE="7"][FONT="Fixedsys"]daboss351[/FONT][/SIZE][/COLOR]
pm with addy or email me.
get er to me and that makes 5 cd's goin out tomorrow:D
Post by: daboss351 on June 11, 2007, 11:17:56 PM
yep its in the DIY link, and ive seen them on my car. just had to think about it lol, my brain is in scrambles cause of exams
Post by: jcassity on June 11, 2007, 11:18:30 PM
When you crimp a lug onto a wire, what are you suppose to put on the wire ot prevent corrosion and promote conductivity?
Post by: daboss351 on June 11, 2007, 11:25:13 PM
i know that one too!
Post by: jcassity on June 11, 2007, 11:25:51 PM
Quote from: 84 Fila;153544
then i guess brian got his?
Post by: 84 Fila on June 11, 2007, 11:28:08 PM
I guess so. I haven't talkes to him today, but if you sent mine and his the same say, I'd bet he got it
Post by: Cougar8775 on June 12, 2007, 10:08:38 AM
if im not mistaking you use ether eletrical tape and heat shrink tubing or just the heat shrink tubing so it is a weather tight seal.
Post by: 5.0willgo on June 12, 2007, 10:16:33 AM
insulating vinyl sleeve.
Post by: daboss351 on June 12, 2007, 11:19:02 AM
no one is right yet! its a substance if im correct which i think i am
Post by: 84 Fila on June 12, 2007, 11:22:30 AM
I know it too. It sucks winning as we can 't play anymore
Post by: daboss351 on June 12, 2007, 11:23:07 AM
but we can hint and play with the others!
Post by: 5.0willgo on June 12, 2007, 11:31:57 AM
As far as substances go, Vaseline.
Post by: daboss351 on June 12, 2007, 11:35:38 AM
it says promotes conductivity, think a grease(special grease) at least thats what ive always been taught
Post by: 5.0willgo on June 12, 2007, 11:37:11 AM
Dielectric grease
I've read that the military often uses Vaseline to inhibit corrosion and not disrupt the electrical connection on battery terminals.
Post by: daboss351 on June 12, 2007, 11:41:30 AM
if i am correct you win!!
Post by: 84 Fila on June 12, 2007, 11:43:22 AM
Di-electric greese and Vasoline are both correct. I use vasoline personaly when I do work though. I give the win to FRED!!!!
Post by: 84 Fila on June 12, 2007, 11:44:48 AM
Next question, since Scott isn't here...... What colour are the "rare" HO CFI injecters....
Post by: daboss351 on June 12, 2007, 11:46:11 AM
you cant do that you dont have prizes!
Post by: 84 Fila on June 12, 2007, 11:58:16 AM
Lol, a hard question though I'll call scott and make sure
Post by: jcassity on June 12, 2007, 10:46:48 PM
Quote from: 5.0willgo;153782
Dielectric grease
vaseline??????? stop doing that because one day someone who knows what they are talking about is gonna be very dissappointed because of how smart you are then you show up with Vasoline to coat wiring before crimping,,,:D
but,,, to save your a$$ and for the win:hick: :hick: :D these two words,,,,,,,"Dielectric grease" will be good nuff. its not grease actually,, and its not an insulator either.
Its called NO-Oxide http://www.oelsales.com/product.cfm/258/
and can be had cheap. The tube you see there can last you for years as it only takes a fine film to prevent corrosion. It fills in the air gaps naturally occuring inside the barrel of a lug between the bands of wire and the inner wall of the lug. With no air present, there isnt much room for other chemestry involved in making corrosion happen.
Most electricians use the black stuff (actually not many use it cause they dont give a rats ass. The tube in the link will someday be held in the hands of someone who works telecom as it appears the color of honey but is transparent when applied cause its so translucent.
so,,,,,,,,,
The winner is,,,,,,,,,,,[COLOR="Red"][SIZE="7"][FONT="Fixedsys"]5.0willgo[/FONT][/SIZE][/COLOR]
pm your addy or email me and the cd goes out tomorrow!!:D
Post by: jcassity on June 12, 2007, 11:03:41 PM
now, to the lotto for a free Electrical Vacuum Troubleshooting manual with all files in jpg format so no special stuff needed to view them. **i hade adobe:beatyoass:
so,,,,,
tell me which pubic circulated kennedy half dollar is the most sought after ,, and why if you wanna explain (optional)
:D
Post by: EricCoolCats on June 12, 2007, 11:56:04 PM
Well...if it was pubic I don't think I'd be seeking it, myself. I like my half dollars completely shaved. :hick:
Post by: 84 Fila on June 12, 2007, 11:58:27 PM
WOW!!! I just noticed that too
Post by: jcassity on June 13, 2007, 12:42:35 AM
Quote from: EricCoolCats;153951
ya know,, i go to work,, come back only to find out someone not only jumped in my playpen,, but they also stole my toys,,,,,,,,,:beatyoass: :D
being that my blood rushed to my head as i almost passed out cause i couldnt grab fila by the nuts :punchballs: and freaking swing him from left ,,overhead ,,, and back to the right again till he sings in disolusion ,,,, i finally decide to calmly ignore the bastaga:flip: and move on. I guess i cant spell, but that aint my subject in homeschool anyway:shakeass:
Post by: P71 on June 13, 2007, 10:21:34 AM
AHAHAHAHAAAA
OK, to answer Mikey's question, their the HO CFI 56#s sitting on my workbench ;)
To answer cassity's question, the one I don't have :hick: 1964 Silver Proof with "accented hair".
Post by: 84 Fila on June 13, 2007, 12:18:50 PM
Thanks Scott... Lol.
Post by: jcassity on June 13, 2007, 11:43:32 PM
Quote from: Aerobird Motorsports;153974
AHAHAHAHAAAA
oh my,, so close,, perhaps i should reword my question and you will see where your answer is wrong but so close to right. For the win,, comon man, you know the answer.
tell me which [COLOR="Red"]public[/COLOR][/B][/B][/I] circulated kennedy half dollar is the most sought after ,, and why if you wanna explain (optional)[/B]
Post by: jcassity on June 13, 2007, 11:47:10 PM
Quote from: 84 Fila;153986
lol,,:D your fine,, i just thought it'd be fun mess with you back.
Post by: 84 Fila on June 13, 2007, 11:52:17 PM
I liked my question though...;) :bowdown:
Post by: jcassity on June 14, 2007, 01:10:10 AM
AHAHAHAHAAAA
awwww,, heck with it,,,
its a public circulated 64 kennedy half dollar,, why? last year halfs, quarters, dimes were sliver. This makes the 64 kennedy half highly desired and also makes it a one of a kind.
and the winner is................[COLOR="Red"][FONT="Arial Black"][SIZE="7"]Aerobird Motorsports[/SIZE][/FONT][/COLOR]
pm with an addy or email me,, congrads.. but,,,,,,
the HO cfi was suppose to have grey tops 52lb/hr. :D
Post by: P71 on June 14, 2007, 10:34:44 AM
I PM'd you.
And they FLOW 56#s ;)
Post by: jcassity on June 16, 2007, 09:19:57 PM
and now back to the loto,,,,,,,FOR A CD of the 1987 EVTM,,
How many nuts hold just the rack/pinion in place?
Post by: Hillbilly Deluxe on June 16, 2007, 09:26:22 PM
None
Post by: jcassity on June 17, 2007, 11:04:33 PM
Quote from: Hillbilly Deluxe;154784
None
umm well i expected any other quantity except for that one:D
none would be a wrong answer.
Post by: 84 Fila on June 17, 2007, 11:06:50 PM
I think he's right, isn't it bolts that hold it no, not nuts>
Post by: SLEEPER T-BIRD 87 on June 17, 2007, 11:12:37 PM
Quote from: 84 Fila;155138
depends on how you remove it:D
Post by: 84 Fila on June 17, 2007, 11:14:16 PM
Ahhh. It's kinda hard to ask about this without givin the answer.
Post by: jcassity on June 17, 2007, 11:15:32 PM
:rollin:
now just think about what you just said:D
Post by: 84 Fila on June 17, 2007, 11:17:15 PM
It made sence when I typed it. Then now that I read it, I feel like a dumbass
Post by: jcassity on June 17, 2007, 11:18:07 PM
Quote from: SLEEPER T-BIRD 87;155139
ahh,, but we aint removing squat:flame:
Post by: jcassity on June 17, 2007, 11:19:04 PM
Quote from: 84 Fila;155146
now i dont feel so bad,, had a day full of those moments today
im mean,,, why even thread the f'ing bolt if it aint got nuts,,lol
Post by: SLEEPER T-BIRD 87 on June 17, 2007, 11:29:47 PM
Quote from: jcassity;155147
I know the awnser but im not going to spoil it for anyone:D
Post by: 84 Fila on June 17, 2007, 11:30:53 PM
I do too!!!
Post by: 84 Fila on June 18, 2007, 12:12:03 AM
它由2枚堅果舉行
Post by: jcassity on June 18, 2007, 12:14:40 AM
ok,, now all of you have the answer,, first one in english wins:hick:
Post by: Hillbilly Deluxe on June 18, 2007, 12:46:46 AM
It held by 2 nuts
Post by: 84 Fila on June 18, 2007, 12:52:01 AM
Winner!!! waiting approval from Scott
Post by: jcassity on June 18, 2007, 12:53:52 AM
And it be a winner [COLOR="Red"][SIZE="7"][FONT="Trebuchet MS"]hillbillydelux[/FONT][/SIZE][/COLOR]
Post by: jcassity on June 18, 2007, 01:03:50 AM
Now back to the lotto
What tire size is required on a Fox trx factory wheel?
Post by: tbirdera on June 18, 2007, 07:33:52 PM
220/55vr 390's
Post by: TurboCoupe50 on June 18, 2007, 08:33:26 PM
Quote from: Hillbilly Deluxe;155176
It held by 2 nuts
Hillbilly you can keep the win, but I disagree... Or I at least consider the answer half correct..
the nuts can be thrown away, the bolts will still hold the rack(for a little while anyway)...:D
Post by: SLEEPER T-BIRD 87 on June 18, 2007, 09:38:34 PM
Quote from: tbirdera;155295
220/55vr 390's
I think your correct :D
Post by: 84 Fila on June 18, 2007, 09:46:13 PM
I do belive yes!!
Post by: EricCoolCats on June 18, 2007, 10:18:19 PM
Not correct...
Post by: SLEEPER T-BIRD 87 on June 18, 2007, 10:22:18 PM
Quote from: EricCoolCats;155344
Not correct...
220/55R390 is what you have listed on your site. give him a break on the speed rating.
Post by: EricCoolCats on June 18, 2007, 10:27:37 PM
Don't recall ever seeing an OEM V-rated speed on TRX tires...
But I forgot, Fila knows everything now.
Post by: SLEEPER T-BIRD 87 on June 18, 2007, 10:35:42 PM
Quote from: EricCoolCats;155350
That shows the replacment sizes avalible 356.00 a tire sheesh!
Post by: 84 Fila on June 18, 2007, 10:39:04 PM
Not evrything Eric, but I got the same answer Russ did.
Post by: EricCoolCats on June 18, 2007, 10:40:00 PM
That's not OEM.
Post by: SLEEPER T-BIRD 87 on June 18, 2007, 10:42:03 PM
Quote from: EricCoolCats;155356
That's not OEM.
The size is just not the speed rating.
Post by: EricCoolCats on June 18, 2007, 10:47:03 PM
You guys are just a treat...
Post by: jcassity on June 18, 2007, 10:51:38 PM
well ,, what do i do now,,
i should have typed the question like so,,,,,,,,,
what metric size wheel was oem from ford ,, example would be the 1984 5.0L coug.
is that better?
tbirdera is in holding pattern for the win!! brb
Post by: jcassity on June 18, 2007, 10:55:36 PM
the answer was a metric wheel / tire offered on my 84coug with xxx - xx- 390
and the win goes to ....[COLOR="Red"][SIZE="7"][FONT="Book Antiqua"]tbirdera[/FONT][/SIZE][/COLOR]
pm with addy or email me at revised@brier.net
Post by: SLEEPER T-BIRD 87 on June 18, 2007, 10:55:49 PM
Quote from: EricCoolCats;155358
my info came from your site.
Post by: EricCoolCats on June 18, 2007, 11:00:53 PM
And you notice there wasn't a "V" in there, was there?
Stock for our cars was an "H" rating, but that wasn't published on the door tag or in the manuals. The "H" was left off, but it WAS an H-rating nonetheless.
Post by: daboss351 on June 18, 2007, 11:01:50 PM
its an awesome cd by the way for everyones who is coming in the mail
Post by: SLEEPER T-BIRD 87 on June 18, 2007, 11:03:31 PM
Quote from: EricCoolCats;155372
And i said Sans the speed rating he was correct.
Post by: EricCoolCats on June 18, 2007, 11:04:05 PM
Tell ya what...what don't we ask 83-88T-Bird Guy? Since he's done just about everything you can do to a TRX wheel, I'll be he's become an expert about the original tires.
Post by: SLEEPER T-BIRD 87 on June 18, 2007, 11:07:24 PM
Quote from: EricCoolCats;155376
Why are you trying to turn this into something it is not.
Post by: jcassity on June 18, 2007, 11:10:48 PM
this is my fault,, i worded it wrong,, all i was looking for was something to do with the word "metric" "oem""390""from the factory
sooooo,, that was informative,, right click save as:D
Post by: jcassity on June 18, 2007, 11:12:37 PM
now,, back to the loto
for the win,,,,,,,,, answer this
of all the fox bodies, which one will and could be more pr0ne to over heating due to nose design?
Post by: EricCoolCats on June 18, 2007, 11:13:03 PM
Were you there standing next to me in 1990, buying brand new TRX tires for my old car at the tire shop?
Because honestly, I don't recall seeing you or Fila there.
Post by: SLEEPER T-BIRD 87 on June 18, 2007, 11:15:53 PM
Quote from: EricCoolCats;155380
Im sorry you are the GOD of these cars... I dont know .
Post by: jcassity on June 18, 2007, 11:22:22 PM
i have 9 cd's left,,, and
this is fun:D :D :D :D :D :D
so.....................
Post by: 84 Fila on June 18, 2007, 11:23:06 PM
Can we get over this please. It's a fight over tires.... Ego's aside, he was right according to Scott. Thats what he was looking for so we're good.
Post by: jcassity on June 18, 2007, 11:23:17 PM
keeping in the spirit of good fun
now,, back to the lotto
Post by: 88cat on June 18, 2007, 11:29:16 PM
87 -88 turbocoupe
Post by: jcassity on June 18, 2007, 11:51:49 PM
:D :D and the winner is [SIZE="7"][COLOR="Red"][FONT="Fixedsys"]88cat[/FONT][/COLOR][/SIZE]
cool beans man,, congrads!!!!!!!!:D :D
Post by: 88cat on June 18, 2007, 11:56:50 PM
pm sent
Post by: jcassity on June 19, 2007, 12:38:14 AM
and now, back to the lotto and for the win,,,,,,,,,,,
you are on pin 26 of your eec.
what is the total resistance of the below circuit?
Post by: amooset on June 19, 2007, 01:25:58 AM
10 ohms
Post by: jcassity on June 19, 2007, 01:44:49 AM
Quote from: amooset;155412
10 ohms
not sure how you got there but ,,,,,,nope,, keep trying , it would be nice to see you win also.
oh,, ok,, now i get where you got 10 from,,,, 30 divided by three. nope, there are two other resistors there to recipricate.
Post by: 88sportcoupe on June 19, 2007, 11:50:38 AM
30 Ohms
Post by: jcassity on June 19, 2007, 12:24:22 PM
Quote from: 88sportcoupe;155470
30 Ohms
nope,,
start with the information you are able to list. every single word in the question has a purpose.
Post by: jcassity on June 19, 2007, 05:06:51 PM
anyone can toss out hints if they want
Post by: 84 Fila on June 19, 2007, 05:09:42 PM
20?
Post by: jcassity on June 19, 2007, 05:11:44 PM
Quote from: 84 Fila;155553
20?
nope,,
the hint is pin 26
Post by: TurboCoupe50 on June 19, 2007, 05:14:27 PM
When I check to see what pin 26 function is I'll give it a shot...
Post by: jcassity on June 19, 2007, 05:16:34 PM
Quote from: TurboCoupe50;155555
:D
now now,, no giving it away,,lol
Post by: TurboCoupe50 on June 19, 2007, 06:58:44 PM
Pin 26 is the 5v reference(should have remembered that)... Since there is .833 ampere current being drawn, resistance is a hair over 6 ohms... 6.0024009 to be exact...
Divide the voltage by current for total resistance of the circuit...
or as Ohms Law states... E divided by I = R
Post by: CougarSE on June 19, 2007, 08:07:55 PM
Quote from: jcassity;155406
10
Post by: jcassity on June 19, 2007, 10:14:07 PM
Quote from: TurboCoupe50;155580
and the winner is [COLOR="Red"][SIZE="7"][FONT="Comic Sans MS"]TurboCoupe50[/FONT][/SIZE][/COLOR]
pm with an addy and ill send you the cd,,, congrads,,, that was too easy eh? the whole drawing was a distractor,, but if you insert the value of 30 ohms for each two unlabled resistors, you get 6 ohms as well. i thought id leave that out since it would make you have to go to what pin 26 does.
of course tom,,, you da man!!
for the posters,,,
in the drawing you got an E over an I and R E could also be V depending on what decade you attended electroics or what engineering style is applied. I-current R-resistance
so if you put your finger over E, you are faced with an I times an R value which will give you voltage. if you put your finger of I, you are faced with an E divided by an R value which will give you current if you put your finger over the R, you are faced wtih an E divided by I value which will give you resistance.
Post by: JeremyB on June 19, 2007, 10:23:23 PM
If you need an EVTM to solve the questions, then what good does giving an EVTM do? ;)
Post by: jcassity on June 19, 2007, 11:00:43 PM
Quote from: JeremyB;155629
circular isnt it? good point but using ones resources could have yielded the missing 5v needed to solve the puzzle.
your location 35s amd 58w you flush your toilet
which way does it spin?
Post by: TurboCoupe50 on June 19, 2007, 11:03:56 PM
I just Yahooed EEC "pin 26" and found the info on the net... Yes I have the '88 EVTM, but was too lazy to go out to the garage to get it... That and I'm so friggin' senile I forgot my '86 Bird and Stang EVTMs are in the bookcase maybe 6ft away...
Scott, Naah wasn't really a hard one, just had to figure out what voltage we were talking about... I'll send a PM ... Thanks...
Tom
Post by: daboss351 on June 19, 2007, 11:05:03 PM
i find it funny i put in the cd, and the name is fila lol
Post by: 84 Fila on June 19, 2007, 11:08:31 PM
Lol, did you get my CD?
Post by: jcassity on June 19, 2007, 11:20:52 PM
Quote from: daboss351;155645
ooppss,, well,, i can explain
umm,, fila won first, and i just kept burnin cd's for about a dozen or so. that means some of you got cd's with the folder named fila.
oh well, everybody's gotta have a little garbage on thier computer:flame:
opps,, did i say that out loud??:moon: :shakeass:
Post by: Warbird9 on June 19, 2007, 11:24:21 PM
counter- clockwise?
Post by: 84 Fila on June 19, 2007, 11:28:46 PM
I'm finally famous
Post by: daboss351 on June 19, 2007, 11:29:06 PM
no i saved it and edited the name
Post by: jcassity on June 19, 2007, 11:48:01 PM
Quote from: Warbird9;155650
counter- clockwise?
nope,, hurry back,, and you got it.:hick:
Post by: Warbird9 on June 19, 2007, 11:57:18 PM
Well, if it's not C-CW, then I guess it's clockwise.
*edit*- I knew that south of the equator it was reverse rotation, I just got me CW and C-CW bass- ackwards!:hick:
Post by: jcassity on June 20, 2007, 08:02:19 AM
Quote from: Warbird9;155662
and the winner is [COLOR="Red"][SIZE="7"][FONT="Fixedsys"]Warbird9[/FONT][/SIZE][/COLOR]
pm with addy or email at revised@brier.net
congrads:bowdown:
Post by: jcassity on June 20, 2007, 10:10:33 AM
How are the v6 CFI and 88 SEFI fuel injection systems related with repect to fuel injector pulsing?
Post by: Thunder Chicken on June 20, 2007, 10:45:08 AM
If the answer is what I think it is, calling the '88 "SEFI" is inaccurate :D
Oh, and the shiznitter question is faulty too. Doesn't matter which side of the equator you're on - the water will rotate in whatever direction the toilet is designed to rotate it:
http://www.snopes.com/science/coriolis.asp
Post by: jcassity on June 20, 2007, 11:18:31 AM
Quote from: Thunder Chicken;155713
i know,, i had a problem with that and how to word it. we figured that one out a while back eh? :D I figured it would leave the answer open to correction and upon dong so, would yield a win
why do i have a feeling this one is a toss out.
Post by: SLEEPER T-BIRD 87 on June 20, 2007, 10:16:55 PM
got my disc today thanks
Post by: TurboCoupe50 on June 21, 2007, 09:32:19 AM
Since no one answered yet(and you said it would prob get tossed anyway)... In those systems there are only two injector drivers in each EEC... The CFI fires one inj at a time, while the EFI(not SEFI) fires three at a time, as they are wired parallel groups and not individually(want me to figure the total resistance :D)...
Ford refers to the systems as "bank fire", which is very confusing... What they mean is bank of injectors, not engine bank(right or left)... GM more correctly(OK less confusingly) refers to these systems as "batch fire"...
BTW the 2.3 turbo uses the same system, as does my '93 Lightning...
Post by: jcassity on June 21, 2007, 12:02:04 PM
Glad that ones gone:hick: thank you tom.
now back to the loto,, i have 6 cd's left so,, for the win,,,,,
Before these.,,,,, there was ..........???
Post by: 84 Fila on June 21, 2007, 12:30:55 PM
What is it?
Post by: jcassity on June 21, 2007, 01:39:20 PM
it is a device constructed of two back to back diodes which by either arsnic or boron doping process increasing or decreasin the valence electrons available within the K shell of the atom, will define thier being silicon or germnium in construction ,, therefore, within the confins of the depletion region will conduct either via hole or electron flow , EMF.:hick: :hick:
Post by: TurboCoupe50 on June 21, 2007, 01:44:10 PM
Quote from: jcassity;156017
For a hint... THESE(it's in there some where)...
Now you see what I've been up to when I went missing here and there...
(http://members.pen 15s.net/35z5/6c46gy6477.jpg)
Post by: CougarSE on June 21, 2007, 06:02:12 PM
Tubes
Post by: jcassity on June 21, 2007, 10:37:51 PM
Quote from: CougarSE;156092
Tubes
drum roll,,,,,,,,,,,,,,,,,,,,,,,,,,, the winner is...........................
congrads,,, pm or email me at revised@brier.net with addy:D :D
Post by: jcassity on June 21, 2007, 10:45:02 PM
now back to the lotto:evilgrin: :evilgrin:
solve:
x= 4 ........... y= -2
-3x – 10(x-y(5-4) + 7) -3
anyone remember my dear aunt sally?
Post by: daboss351 on June 21, 2007, 10:49:21 PM
i can do that shiznit!! i went to sylvan im smart!!!
Post by: 32VFoxBird on June 21, 2007, 10:59:53 PM
umm, 85?
Post by: jcassity on June 21, 2007, 11:02:25 PM
Quote from: 32VFoxBird;156153
umm, 85?
nope,, you can use a calculator you know,,,:D
pay close attention to "Y" in the early stages of this problem or you'll hose it up.
and while we are on the topic,,, if multipication is just a short cut way to addition,, then why is a negative times a negative , A postive? thats always bugged me.
Post by: daboss351 on June 21, 2007, 11:12:10 PM
hint a subtracting a negitive is like adding a positive
Post by: V8Demon on June 22, 2007, 08:07:32 AM
-145
Pemdas Ftw!
Post by: jcassity on June 22, 2007, 11:42:43 AM
Quote from: V8Demon;156204
-145
Pemdas Ftw!
and the winner is,,,,,,,[COLOR="Red"][SIZE="7"][FONT="Verdana"]V8Demon[/FONT][/SIZE][/COLOR]
This problem came from my math cheet sheet quick reference guide i put together for homeschooling with an explaination. X=4 Y= -2
-3x – 10(x-y(5-4) + 7) -3 -3x – 10(x-y(1) + 7) -3 -3x – 10(x-(-2)(1) + 7) -3 ** insert -2 for Y but y was negative as well so a negative times a negative is a positive -3x – 10(x+2(1) + 7) -3 -3x – 10(x+2 + 7) -3 -3x – 10(4+2 + 7) -3 -3x – 10(13) -3 -3x – 10(13) -3 -3x – 130 -3 -3(4) – 130 -3 -12– 130 -3 < here is where some people get confused. When you have a bunch of negative numbers in a row,, you only need to add them up as though it were money you owe. So,,, you owe 12 then you owe 130 then you owe 3. No matter how you look at it, your still adding in a negative direction. Answer : - 145
The only difficult part of this problem is watching when you first insert the value of Y into the problem.
Post by: jcassity on June 22, 2007, 12:18:14 PM
and now,, back to the lotto......
You have been told that your sluggish starting problem might be caused by a starter relay/solenoid getting worn out or the same for the starter.
you end up installing a new starter relay and suddently your car does not start. NO click, no crank, no nothing. you have interior power / radio / headlamps/ instruments ect but no crank.
whats likely to be the problem?
Post by: jcassity on June 22, 2007, 04:46:26 PM
i need addy's from the following members,, please pm
thnx scott
warbird9
cougarse
V8Demon
Post by: cougarcragar on June 22, 2007, 08:01:54 PM
You overtightened the two posts on the solenoid, therefore creating internal pressure (warping?) and ruining the new solenoid.
That's my guess... yah, I've done it. :D
Post by: jcassity on June 23, 2007, 12:39:19 AM
Quote from: cougarcragar;156345
:rollin: :rollin: :rollin: :rollin: :rollin:
nope,, hint,,, what did you do wrong? what was the one thing you did not do?
Post by: 84 Fila on June 23, 2007, 12:43:16 AM
*hint* think of what came off, and whats not there now
Post by: cougarcragar on June 23, 2007, 12:48:27 AM
The ground cable for the starter motor? I'm out of ideas. :D
Post by: 84 Fila on June 23, 2007, 12:50:26 AM
Not quite, but on the right track
Post by: jcassity on June 23, 2007, 12:55:18 AM
ahh,, your getting so much warmer........... hows about you go out and look at that solenoid real close,
this makes an awsome prank to pull on someone...:hick: :hick:
hint again,, has something to do with the transmission.
Post by: 84 Fila on June 23, 2007, 01:05:25 AM
*Calmly sits and desk and raises his hand*
Post by: jcassity on June 23, 2007, 11:08:09 AM
oky dokey,, last hint
what did you forget to connect:D
Post by: 84 Fila on June 23, 2007, 12:31:39 PM
*hint* it's a wire that was missed and not re-hooked up. Re-read th question then go look at your car.
Post by: gumby on June 23, 2007, 12:45:10 PM
rd/blu start signal isnt hooked up
Post by: jcassity on June 23, 2007, 03:18:30 PM
:hick: and the winner is,,,,,,,,, [COLOR="Red"][SIZE="7"][FONT="Comic Sans MS"]gumby[/FONT][/SIZE][/COLOR]
pm with an addy and ill get you a cd,,,,,,,,,congrads:hick:
Post by: jcassity on June 23, 2007, 04:39:24 PM
now back to the lotto..........:D
i need addy's for the following people
gumby
warbird9
cougarse
V8Demon
i am down to one cd,,,,,,,,,,THE LAST ONE
who will be the winner?
for the win:D :D :D :D :D
how many numbers are there?
Post by: amooset on June 23, 2007, 05:47:37 PM
10, zero through nine.
Post by: jcassity on June 24, 2007, 12:04:19 AM
Quote from: amooset;156443
and the winner is,,,,,,,,[COLOR="Red"][SIZE="7"][FONT="Comic Sans MS"]amooset[/FONT][/SIZE][/COLOR]
congrads man!!!!!!!!!!!
pm me with an addy or email me at revised@brier.net.
Post by: jcassity on June 24, 2007, 12:10:49 AM
thanks to everyone,, this was pretty fun to say the least. I hope everyone enjoys the EVTM and all its information for many years to come.:D
you all are great!! round of applause for all the winners!!!
if you name appears without a dash,, i still need your addy please.
Post by: 84 Fila on June 24, 2007, 12:14:25 AM
C'mon, give some more questions for fun. Thanks for the Win Scott. It was great playing
Post by: jcassity on June 24, 2007, 12:20:45 AM
Quote from: 84 Fila;156509
my pleasure:bowdown:
Title: last call
Post by: jcassity on July 01, 2007, 12:00:14 PM
EVTM loto winners,,,,,,,,,,
i need addy's from
warbird9
cougarse
and,,,,,,,,,DID EVERYONE RECIEVE THIER CD?
Post by: SLEEPER T-BIRD 87 on July 01, 2007, 07:55:07 PM
yes sir i got mine and have used it on several occasions!!!! thanks
Post by: 84 Fila on July 01, 2007, 07:59:15 PM
Scott, you know I got mine.And though I haven't really hardcore used it yet, I have looked through it and learned a bit
Post by: amooset on July 01, 2007, 10:48:11 PM
Got the CD yesterday. Thanks!!
Post by: jcassity on July 02, 2007, 09:57:32 AM
ok, just checking my tracking system here,,, thats why i have two cd's sitting here and it confirms the owners.
warbird9
cougarse
comon guys,, :D
otherwise,, leme know who you want to donate your win to.
Post by: jcassity on October 11, 2008, 02:55:38 AM
ok here goes again........lets have some fun.
What member on this board said the following
"Fox Birds and Cougars are like herpes. You can never get them totally out of your system. No matter how long you go without showing any symptoms, they will flare up again at some point"
Post by: dw43935 on October 11, 2008, 03:53:39 AM
