Marketplace => T-Bird/Cougar Parts & Cars WANTED => Topic started by: 87tbirdmanjwg on May 12, 2007, 09:35:56 PM
Title: window glass for a 87' tbird with manual regulators
Post by: 87tbirdmanjwg on May 12, 2007, 09:35:56 PM
Just like the title says. I have all My parts for a manual regulator conversion except the glass. I tried drilling holes with a glass bit but that didn't work...It was a shattering experiance:hick:
Post by: vinnietbird on May 13, 2007, 12:40:58 AM
The windows are different between auto and manual door glass??
Post by: 87tbirdmanjwg on May 13, 2007, 03:35:14 AM
Yep... the manuals have two holes for mounting (at least the 83' to 86') and the power glass has the siliconed-on tabs.
Post by: vinnietbird on May 13, 2007, 09:18:48 AM
Oh,now I see.I'll check around for you.I took a piece of glass (totally non car related) to a glass shop(Installed windows,cut mirrors,etc.),and they can drill holes in glas.they have the specialized equipment to that.
Post by: cougarman on May 13, 2007, 12:07:02 PM
you got your manual regulators from an 83-86? then you can use power glass from a 83-86 then as they are diffrent from 87-88
Post by: 87tbirdmanjwg on May 13, 2007, 12:49:50 PM
I had the glass from the car I took the regulators from, but they would not fit the 87' tracks. The older glass is shaped slightly different; for instance the top rear corner of the 87' glass is round, the older manual regulator glass is 90 deg. sqaured. Also, the older glass is about a 1/4 inch longer....
Post by: cougarman on May 13, 2007, 12:55:03 PM
well that sucks, the 1\4 longer shouldnt be a prob because the 83-86 doors have a larger window opening than the 87-88 so if you could get around the corner deal you should be fine.
Post by: vinnietbird on May 13, 2007, 01:09:07 PM
Is there a way to adapt the '87/'88 window clips to the manual window regulators?Drill a hole in them to accept the '87/'88 clips?Just a thought.Finding manual windows for an '87/'88 is probably going to be pretty hard.
Post by: 87tbirdmanjwg on May 13, 2007, 01:55:22 PM
Quote from: vinnietbird;146933
I was just thinking that as an option...I'll give it a shot.
Post by: vinnietbird on May 13, 2007, 04:07:23 PM
Depending on the location of the clips on the glass as opposed to the lifts of theregulator,you may have to remove the clips and repostion them.No big deal.
