Technical => Engine Swapping => Topic started by: troys86 on May 12, 2007, 05:44:50 AM
Title: transplant
Post by: troys86 on May 12, 2007, 05:44:50 AM
hi guys i am new here.i am doing a 2.3 to a 5.0 swap and i cant seem to find any engine mounts any were.ford tells me that only ones that will work are 86-88 5.0 mounts
Title: transplant
Post by: vinnietbird on May 12, 2007, 08:53:44 AM
I have a set,but you'll have to go to Autozone to buy the rubber insulators for them.I'll let them go for $50.00 shipped.If you can find them cheaper,grab them.Otherwise,you know where a set is if you need them.They are not made aftermarket like the Stangs.Chuck W here on the forum sells some he designed and are supposed to be pretty great.I can't tell you how much,I have no idea.
Title: Motor mounts
Post by: billwrks on May 15, 2007, 12:17:16 PM
Look in the tech part on main page. You will find all the correct things you need! I swaped out my 3.8, for a 302! had major problems with the 302, so dropped in a 351 W...:)
