I saw a Harness conversion kit for Mass Air on E-Bay.It has the wires,instructions,and I have to supply the computer and Mass Air Meter.My question is,when installing Mass Air on our cars,is it exactly like doing a Stang?Or,are there a few differences between the two as far as the wiring for Mass Air would go?
Pretty much the same. As per Coolcats:
PROCEDURE & NOTES
I posted a colour diagram of where the wires should go awhile ago too.
Vinnie just take the plug from a yard with enough wire to splice into it,probably free and no shipping.
Won't a Stang harness just swap right in with no mods at all,then all I need is the Meter and computer?
no. The tbird wiring is different.
Where is that diagrahm,I thougt I saved it but couldn't find it.That was a good one.
I'll probably buy the kit I saw on Ebay.it has the plug with wires and instructions.If anyone has a nice accurate wiring diagram,shoot it to me.
The hardest thing is gettin slack on the computer wiring to make a good connection.
buy the kit you said i don't need has everything!
I can buy the computer,Mass Air meter and wiring kit for less.That kit is a little over 120.00,but it'll climb higher before it's over.Those kits are not cheap at all.Plus,I have friends who have salvage yards.I'll go there and load up on what i need for cheap.
well then get 2 of each!
The only mustang harness that would plug in would be an 88 harness.. But its not mass air.
Vinnie emailed you the wireing from 1wld brd.
