Technical => Engine Tech => Topic started by: cougrrr302 on April 11, 2007, 09:40:05 PM
Title: Heads, cam, intake.....or 306 info
Post by: cougrrr302 on April 11, 2007, 09:40:05 PM
When I get around to it. I would like to give my 5.0 alittle more go. Just like anyone else does. Mine is an 84 CFI. I know I need a cam with more exhaust duration that intake, and thats about all I know. Im just looking for recomendations. I would like to rebuild to a 306 and any/all info on that would be appreciated too.
Post by: V8Demon on April 12, 2007, 09:18:42 AM
How much more go is a little more go in your opinion?  What exactly do you want out of the car?
Post by: TurboCoupe50 on April 12, 2007, 10:26:57 AM
Quote from: V8Demon;139602
Good call...
With it being a CFI system you options are limited unless you go carbed or convert to the later SEFI... Guess it would be possible to use either a '84-'85 Mustang or LSC throttle body(with it's correct injectors), EEC and cam to produce the 180hp CFI HO... With headers and free flowing exhaust system you could probably squeeze out 200hp...
As far as I know no one(on here) has performed such a mod on a Bird/Coug.... Be the first on your block!!!!
Some years back on the old Easyboard someone did stick a CFI on a HO, but I don't think it ever ran exactly right... Can't remember what EEC and throttle body he used though...
Post by: V8Demon on April 12, 2007, 04:14:32 PM
So he stuck a CFI on an SEFI car or an earlier carbed?
Post by: TurboCoupe50 on April 12, 2007, 06:17:42 PM
Quote from: V8Demon;139687
If memory serves me correct, it was a late HO swapped into a '84-'85 Cougar, with the CFI piled on top(reinstalled)...
Maybe someone else has a better memory of it...
