Technical => Engine Tech => Topic started by: tbirdera on April 01, 2007, 07:25:08 PM
Title: help with t bird studdering !! (TIRED OF THIS)
Post by: tbirdera on April 01, 2007, 07:25:08 PM
well my 88 tbird wit a 5.0 when cold in da morning shuts off when startign upo it goes on den lowers n rpm n den shuts off.. i changed lots of things such as new gasktes all aorund , lifters, tps ,water pump, pcv valve , water sensor locatce don teh intake and i still cant see wat the hell it is.  but i dotn hav ethe egr connected cuz i have no idea how it is. what i havent changed was the o2 sensors .. i noticed that on one hot day i startedup da car and it stayed on.. could it be the o2 sensors??  HELP!!!!
Post by: vinnietbird on April 01, 2007, 07:33:40 PM
What about the IAC?Have you run codes?The EGR should be plugged in.
P.S.  That was one of the most difficult posts I've ever tried to read.
Post by: 5.0willgo on April 01, 2007, 07:54:28 PM
^Agreed
Remove the Idle Air Control valve and spray it out with some throttle plate cleaner. Once you remove it, you'll see it's probably all gummed up inside. Spray it clean.
See if it is throwing any error codes. If you can't or don't have a way of doing it, take it somewhere like AutoZone. They check them for free.
If you disconnected the EGR, plug the line that plugged into it with a screw so it's blocked off and not just open to air.
Post by: Jim_Miller on April 01, 2007, 10:51:26 PM
Quote from: tbirdera;137682
I'm thinking this translates to he doesent know where the EGR hooks up or what line goes to it in order to plug it in.
But I can't help with that as I don't know myself.
Whats an EGR look like?
Post by: JeremyB on April 01, 2007, 11:21:40 PM
Quote from: vinnietbird;137683
Have you run codes?
Quote from: 5.0willgo;137688
^Agreed
So...
Post by: tbirdera on April 02, 2007, 11:46:53 AM
ok ok umm sorry for the post to be all hard to read lol i was pissed writin this.. um i changed the iac in teh summer and it still did the same thing..  i have one green line and one red line that doesnt do  that is connected under the hood hindge on the pasender side.. and i have one black line that is connected to the intake that has hair constantly coming out and it makes liek a psssst sound... how do i connect them??  or should i leave em out??
about the iac its brand new not even a year old.. wat should i do about it..
Post by: 5.0willgo on April 02, 2007, 12:07:26 PM
That pssst sound is a vacuum leak. That explains why your car stalls. I had the same thing happen to me.
These lines you are talking about are all small hard plastic lines around the diameter of a toothpick?
It's rather difficult to figure out all the connections without some visual aid.
If you are able to post pictures of what exactly you have there, we can probably help much better.
Since you replaced the IAC, you shouldn't have to do anything else with it. It should be fine.
Post by: tbirdera on April 02, 2007, 12:16:51 PM
yeah yeah exactly bro .. umm ima get pictures in a few
Post by: tbirdera on April 04, 2007, 02:46:03 PM
ok i got some pics man here u go
Post by: tbirdera on April 04, 2007, 02:48:00 PM
1 more pic
Post by: MasterBlaster on April 05, 2007, 09:03:01 AM
Visual aid?
Your second pic seems to show you have EATC (Electronic Automatic Temperature Control), so your hoses may be slightly different.
(http://www3.telus.net/neat/pics1/vac_hose_routing.gif)
Post by: tbirdera on April 07, 2007, 01:07:52 AM
yeah i have electronic temp control.  so is that  how my stuf shoudl look?
Post by: SLEEPER T-BIRD 87 on April 07, 2007, 10:18:53 AM
Quote from: tbirdera;138712
yes,except you will not have the line that goes in the firewall (it will be capped)
Post by: tbirdera on April 08, 2007, 12:34:10 PM
o0o great thanks guys ima  see wat i can do now i gotta wait till monday to buy soem new vaccum lines
Post by: tbirdera on April 08, 2007, 12:34:55 PM
oops double posted .....
