Technical => Drivetrain Tech => Topic started by: jgonza2 on March 24, 2007, 02:23:54 AM
Title: Will 3.31 ring pinion fit my 7.5 rearend?
Post by: jgonza2 on March 24, 2007, 02:23:54 AM
I've got the stock rearend with 2.73 gears and I'd like to get a bit more green light get-up-n-go out of my H.O.  This car is my daily driver so I don't want too much gear--especially with today's (AND TOMORROW'S) gas prices;  My normal driving pattern is 80% street and 20% freeway (during rush hour).  So, I'm wondering if the ring and pinion from a 2007 V6 mustang will fit my 7.5?  Thanks.
Post by: dudeman351 on March 25, 2007, 06:42:29 PM
Are you talking about just changing the gears or swaping the chunk?
Because if you just change the gears there might be a difference in carrier size. but if you change the chunk you should be ok.
louie
Post by: jgonza2 on March 25, 2007, 07:20:44 PM
I am talking about just changing the gears...I thought all ford 7.5 rearends might be the same.
Post by: Thunder Chicken on March 25, 2007, 10:28:30 PM
I thought all '05 and newer Mustangs had the 8.8", which would make sense considering that V6 models now make almost as much power as the Fox 5.0 did...
Post by: Jim_Miller on March 26, 2007, 12:39:13 AM
I have a set of 3.27 from a 7.5 out of a 1984 Mark VII I would let go pretty cheap
Post by: BadShoe on March 29, 2007, 09:19:09 PM
The new Mustangs still have 7.5" in the 6 cyl. but the GT's 8.8" are 31 splined.
Post by: dominator on March 29, 2007, 09:35:36 PM
You sure???
I thought they stopped making the 7.5 rear???
Went 3.27s in mine when i had it,it is the largest you can go and still keep the speedo accurate with a 21 tooth gear.
Post by: V8Demon on March 30, 2007, 08:57:51 AM
That is correct.
