Technical => Body/Appearance/Interior => Topic started by: Ether947 on March 09, 2007, 01:46:16 PM
Title: Dent Repair
Post by: Ether947 on March 09, 2007, 01:46:16 PM
Is there an easy way to repair the dent in this pic?
(http://i69.photobucket.com/albums/i78/ether947/DSC02441.jpg)
I did a search and most said that Paintless Dent Removal from a body shop was the way to go. But that DIYer in me, is curious if one of those "too good to be true" devices work.
Thanks,
Antonio
Title: Dent Repair
Post by: Chuck W on March 09, 2007, 01:59:08 PM
Well it's in a hard spot to get to.  Can you get behind it at all from the trunk?
Title: Dent Repair
Post by: 5.0willgo on March 09, 2007, 02:01:25 PM
Yeah, go paintless dent repair. Shouldn't cost more than $130.
Those pops-a-dent plunger things don't work. You might have some luck hammering it out but it ain't gonna be purdy.
Title: Dent Repair
Post by: EricCoolCats on March 09, 2007, 02:16:04 PM
Pop-a-dent things are good for a flat area with a big dent. You get into curves like that and it's a disaster.
I guess there's only one way to find out, with paintless dent removal. That is a very tricky spot though. Like Chuck said, if it can be reached through the trunk then it can be popped out from the inside.
Title: Dent Repair
Post by: Ether947 on March 09, 2007, 02:36:41 PM
Quote from: Chuck W;133444
I'll take a look tonite or tomorrow.
Title: Dent Repair
Post by: Ether947 on March 09, 2007, 05:48:32 PM
Nope, can't get to it from the trunk.
Title: Dent Repair
Post by: SLEEPER T-BIRD 87 on March 10, 2007, 10:32:54 AM
Get one of those DIY paintless dent remover kits like walmart sells for 20.00 ive had good luck getting dents out of compound curves like that with them as long as there are no sharp creases in the metal (wich yours look alright)
Title: Dent Repair
Post by: HAVI on March 10, 2007, 03:51:01 PM
if nothing above works, consider drilling a hole thru the trunk and stick a pick-rod thru and push it out as best you can.  Then seal the trunk hole back up.  my 2 cents.
Title: Dent Repair
Post by: Tbirdmaniac on March 10, 2007, 05:20:17 PM
Bad damaged area!!!, there are a shock tower just behind here, and trunk reinforcement here, If You unable to push the bumped area with a piece of 2x4 cutted in angle, and a hammer, I agree with HAVI to pull out, but You will need to reface the fender after this, but with the time and PATIENCE I'll guess You will able to push by the trunk, with some wood pieces, and pry out the panel...
Regards,
Dom.
