Technical => Engine Tech => Topic started by: JKATHRE on February 21, 2007, 08:16:16 PM
Title: Marbles Galore
Post by: JKATHRE on February 21, 2007, 08:16:16 PM
Wife complains that marble noise is coming from the '88 TB 3.8 engine.  I investigate with my ear and it seems to be on both sides. Today, I removed the belt and found squeaks on the smog pump---it's original with 120K on it.  As for the alternator and maybe belt tensioner, could not hear anything strange other than the tensioner pulley had a little side play in it.  The alt is newer ...So I figure it's the smog pump with an echo for both sides---does this make sense?
I then drive the car and find the temp gauge needle running higher than I like to see it in this weather.  I assume it represents a sticking thermostat--is that a reasonable theory?  There have been 3 thermostats on this TB and now I think #3 is kaput (4 years old).
John R
Post by: stuntmannick on February 21, 2007, 08:54:46 PM
Sounds like a water pump problem.
Post by: JKATHRE on February 21, 2007, 10:49:47 PM
I didn't really think of the water pump--but admit it's old--I last did that one in 1995.  The hub seemed to turn ok but that leaves little with clues.  There's no leaks from the pump--but now with the temp gauge in mind, I'll look again this weekend.  Thanks.  I hate to throw parts at a repair but did order the smog pump---the cheap one was not the right one to fit, so naturally I had to fork over another $15 to order one with the right hose mountings.  We had to leave the bird out a few times in the cold in February (0 degrees) and I think it didn't like that being the senior citizen it is.
Post by: Old_Paint on February 22, 2007, 09:04:33 AM
The temperature gauge problem could be the IVR (Instrument Voltage Regulator) on the back side of the cluster.  Is your oil pressure also reading higher?  I chased high temperature problems that didn't exist on my '86 for a long time.  A dealer fried my cluster for me, and I found one from an '87 to replace.  Suddenly, after installing the replacement cluster, my temperature problems went away.
Post by: 5.0willgo on February 22, 2007, 04:18:28 PM
Hmm, temp guage high, marble like sound coming from the engine.
Sounds like a possible head gasket to me.
Check the oil to see if it's milky and check the compression.
When my head gasket blew on my 5.0, I had a nasty marble sound coming from the motor and it would blow some black smoke out of the pipes. It never overheated though and the oil looked fine. BUT, a friend of mine had a 3.8 that over heated, had a milkshake for oil and sure enough it was the gasket.
Post by: JKATHRE on March 03, 2007, 11:47:38 AM
Hey,
Put a new smog pump on last week and the marbles are gone.  Seems like there is still a ticking sound somewhere, but that is less disturbing.  For now, the problem is over.  Apparently there are 2 kinds of smog pumps listed for this Tbird.  The more expensive one has both external hose fittings fixed onto it and that's the one I needed.  Good thing I checked the first one given me by comparing it to the existing one in the store parking lot--had to go back in and reorder the other and wait several days. If I had taken this for granted--bringing the old in first to pick up new--I would have had to reinstall the old and wait--as the one I needed was not in stock.
