Technical => Misc Tech => Topic started by: ipsd on February 19, 2007, 12:45:55 AM
Title: Need some help.
Post by: ipsd on February 19, 2007, 12:45:55 AM
I'm going to pick up a 94 cougar tomorrow. I need to install the A/c clutch to be able to drive it. I can't find any info about this in my Chilton manual. It did come with some instuctions. They are very hard to understand. So if any of you have experence with how to install these or have any info that tells how let me know so I  can get this figured out.
Post by: 5.8fastcat on February 19, 2007, 11:36:00 PM
You will need a special puller to get the clutch off.
  I think they make a A/C delete for those cars. It bolts in place of the A/C comprssor to keep stock lenght belt.
  At my shop when a car needs a A/C  clutch it gets the whole compressor.
Post by: ipsd on February 20, 2007, 09:20:48 AM
Thanks for the help. I don't need to take the other clutch off there. The P.O. already had that off. He took it off the cougar to fix his grand mark. So I just had to install the clucth on the compressor. With the clutch came an install sheet. It did say somthing about a clutch hub installer. Anyhow I got it installed and got it home. The car runs great. I can't complain. It only cost $200.00
