I am lookin for a fuel tank sending unit/pick up from 83 tbird or cougar... the 22.1 gallon tank with pump on the engine let me know if you have one and how much... shipping would be to 97479
Sincerely,
Eric
If a pump/sending unit from a 88 TC will fit I got one of those, it works fine. It would go for cheap, it worked when car was last on the road a few years ago, but can still be jumpered and does cycle. It only has 45,000 miles on it. Say like 20 shipped, if you can use it.
Dave
the reason im lookin for the 83 one is because they used a pump ON the engine with some vehicles and id like to use the proper sending unit and pick up for a carburated set up instead of tearing it apart and putting it back in hoping it works lol... so the 88 TC wouldnt work if you understand what i mean
the diameter of the sender on the 83 is smaller than the 86+ tanks so if you are going carberated you will need the whole tank. i tried this already
my cougar is an 84 ;-) so its the same diameter
http://cgi.ebay.com/ebaymotors/NOS-1983-TBIRD-COUGAR-5-0-FUEL-PUMP_W0QQcmdZViewItemQQcategoryZ33555QQihZ012QQitemZ220005540745QQrdZ1QQsspagenameZWD1V
not sure if this helps
not my auction btw
that looks as if its got a pump on the unit...... i know ill figure something out
