General => General Fox T-Bird/Cougar Discussion => Topic started by: Tbirdmaniac on December 30, 2006, 09:07:44 PM
Title: Tripminder info needed?... FOUND!...
Post by: Tbirdmaniac on December 30, 2006, 09:07:44 PM
Hi!,
I swapped last winter My base electronic cluster for a full digital cluster, no problems last summer at all, except this f***in FUEL FLOW INPUT wire (LB/PK harsh) supposed to connect on a pin 34 of the computer behind the right front kick panel...
The problem is I have a CARBED engine in My Bird, and don't have any computer as well, I checked on the entire internet, and in the EVTM Ford manuals I have, and except the info I already have, I don't see anything help Me for a carbed engine...
What is the output of this ed pin 34 of the ECA/ECC, a variable voltage, a modulated voltage at ??? HZ, variable resistance????, I don't know what!...
I checked at the junkyards for an carbed old full sized/equipped fords, nothing like that...
I guess for the carbed engine is a kind of vacuum box connected to the same vacuum of the distributor advance, and convert the vacuum to a variable voltage, or whatever!!!...
If anyone in this board have an advanced info on that, this will be VERY VERY appreciated, because without this "fuel flow input" connected, the tripminder is VERY not accuracy...
Note: The full digital cluster and clock tripminder need the same signal from the pin 34 of ECA/ECC...
Happy new Year...
Post by: softtouch on December 30, 2006, 09:37:39 PM
from the '84 EVTSM page 88:
Pin 6 of the Tripminder Module has a LB/PK H wire to ECA pin 34
OR for Canada only carbed 3.8, Pin 6 has a white wire to a fuel flow sensor.
Component Location:
Fuel flow sensor--Between carburetor and RH fender apr0n.
Post by: softtouch on December 30, 2006, 09:56:37 PM
This is a guess but I think the fuel line runs through the flow sensor.
Post by: pro-five-oh on December 30, 2006, 10:15:24 PM
Quote from: softtouch;120848
Correct.
You need to find the fuel flow sensor from a 1978-up Ford/Lincoln/Mercury that has a carb and a tripminder.  I don't have a pic handy, but they do exist and its what you need.
Post by: Tbirdmaniac on December 30, 2006, 11:13:29 PM
AHHHHHHHH!, Thank You very VERY VERRRRRY much guy's, this My New Year gift :D
Curiously, I checked at a Ford site for Motrocraft parts in a Lincoln and Mercury division and I not see this sensor, I'll recheck, But, I'll go at a "giant" syard near Me when It reopen the 8th, and he have a lot of old cars here (around 4000 cars total), I never believe I'll not found at this place eh?...
I'll re-post when I found this gizmo, and post a pic of that...
Again, thank You very much...
Happy new year!.
Post by: MasterBlaster on December 31, 2006, 09:37:12 AM
They chat about Tripminders in carbed Crown Vics too...
http://www.grandmarq.net/vb/showthread.php?t=12113&page=2 (http://"http://www.grandmarq.net/vb/showthread.php?t=12113&page=2")
And Cardomain (same guy, same pics)...
http://www.cardomain.com/ride/2157112/12 (http://"http://www.cardomain.com/ride/2157112/12")
Post by: pro-five-oh on December 31, 2006, 01:10:25 PM
I found a pic of it, but I have no scanner. :(
Go to your Ford Parts dealer and ask them for a screen shot of the fuel flow sensor for a 1982 Lincoln Continental.  (that's the fox body Lincoln).
Get that sensor and you're set. Good luck, mang!!!!
Post by: Tbirdmaniac on December 31, 2006, 07:21:07 PM
Hello,
Curiously, last night after a couple of hours of research with Google, I found this board (grandmarq.net) and see a couple of pics of the fuel flow sensor, on the marquis/Crown vic, it seems to bolted on the intake, just between carb and right valve cover...
I guess I'll founs at the "giant" syard near Me, he have a lot of old cars, like a full sized Marquis/Crown's and Lincolns...
Quote from: MasterBlaster;120890
I'll go to see that too just after this msg...
Thank You very much, HAPPY NEW YEAR!!!:dunce:
Post by: Tbirdmaniac on December 31, 2006, 07:27:03 PM
Hi!,
I found a scanned page at http://www.grandmarq.com and the fuel flow sensor have three wires, such a BLACK=negative, RED=Positive, and YELLOW (I guess)=output to tripminder...
Quote from: pro-five-oh;120916
Yeah, I'll found at the junkyards for sure, and I'll try to found a couple of others for My other bird, and My Ford van, I have a clock tripminder for that...
Again, Thank You very much, and HAPPY NEW YEAR!!!.
Post by: pro-five-oh on January 01, 2007, 03:35:50 PM
Quote from: Tbirdmaniac;120949
Which Ford van can you put a Tripminder in?  That's pretty cool!
Post by: Tbirdmaniac on January 01, 2007, 09:31:56 PM
Quote from: pro-five-oh;121063
Hello!,
A full sized Ford Econoline pic below, I putted out a digital speedometer from a Lincoln town car last year to fit in My truck, this speedo is drived by a standard wire between trans and speedo, like the lincoln digital I have, and this speedo have a speed sensor output, I just put this wire to the clock tripminder and the fuel flow sensor out to the clock too, and that's it...
The problem it's fit the digital speedo in the cluster to work correctly, and to do good cosmetical appearance, I have 3 or 4 econoline clusters here, and if it's to hard or much trouble to fit in, I'll fit a Tbird/Cougar digital speedo unit in the cluster...
The only bad thing is the clock in the truck is placed very away at the left of the drivers side, and not very easy to push the buttons when You drive the truck, another thing, on the day when the sun is at left rear You don't see anything due to the sun reflection...
Anyway for the truck is not an emergency, I'll do this summer when I use only My truck time to time...
Post by: pro-five-oh on January 02, 2007, 03:08:07 PM
Hey now that's a good idea!  I thought a tripminder would just bolt in, but what you're doing there is pretty trick!!!
Post by: Tbirdmaniac on January 02, 2007, 08:07:55 PM
Hi,
Before I do this on My truck, Ill go hunting in a differents syard to found this  fuel flow sensor, I'll need 3 or 4 just to have a couple in spare cauz it's very rare gizmo...
