Technical => Body/Appearance/Interior => Topic started by: Dansbirds on November 03, 2006, 10:52:26 PM
Title: Center Console Question
Post by: Dansbirds on November 03, 2006, 10:52:26 PM
Time for the consolette to vanish. I have a center console to put in but am curious if I need more parts. Will I need a new center dash trim piece? Also I believe I must remove the ashtray assy but what goes in its place, anything? Thanks for the help. the car is an 87 if it helps
Post by: Thunder Chicken on November 03, 2006, 11:59:16 PM
You'll need the center dash trim piece, an ashtray blockout panel (either a "systems sentry" or plain lighter panel), and some brackets - the one that mounts the leading edge of the console to the dash and the one that mounts the back end to the floor. If you don't already have it you'll need the switch panel and shifter bezel (or delete if you're staying with column shift)
You'll also need to strip your driver's seat base and cut the consolette off. It's actually a welded on, structural part of the seat.
Post by: Ifixyawata on November 04, 2006, 12:03:48 AM
Here's a fun fact for all you Consolette people converting to console.  If you get brave and go under the car, there are dimples located where the 'stock' location for the full/mid-console mounting holes are supposed to be.  I noticed this after I installed my console and nothing lined up right.
Post by: vinnietbird on November 04, 2006, 07:19:12 AM
When I converted mine,under the carpet in my car,the holes were already there for the console brackets.I cut the carpet,cut a hole in the floor of the car for the shifter,and all the bits and pieces from the donor car bolted right in.The shifter was a small challenge,but it all looks factory done.
Post by: Dansbirds on November 04, 2006, 05:20:03 PM
Thanks guys for the info. looks like all i am left to get is the lighter panel then. I got the console for 20 bucks and its like new complete with the tray(my car is column shift) and all the switches witch is the same set up as I have now.
Post by: vinnietbird on November 05, 2006, 07:07:38 AM
Sounds like you're on your way.Take your time,and look everything over for fit a couple of times.Good luck and keep us posted on your success.
