Technical => Engine Tech => Topic started by: Chris1987LX on October 23, 2006, 09:31:31 PM
Title: My V-6 needs some help
Post by: Chris1987LX on October 23, 2006, 09:31:31 PM
Well I have the dreaded engine surge problem, as well as the thing stalling out on me.
I bought a remanufactured distributor w/module, but the ed thing doesn't work properly and I have to return it this week.
Has anyone else had the same problem of reman. distributors not matching what's in the car?
Chris
Post by: 88turbo on October 23, 2006, 10:49:07 PM
check your TPS.  that was where my surge problem was as well as my stalling.
Post by: V8Demon on October 24, 2006, 08:35:19 AM
TPS, IAC (dirty or dead, either one), egr valve stuck, idle set too low, whatever else I can't think of right now.......
Post by: Chris1987LX on October 24, 2006, 02:05:05 PM
Thanks folks.
The TPS, as well as all engine sensors, are new - they have about 6,000 miles on it since installing them in 2003.  Although the TPS could have went bad...who knows. The car rarely sees the road outside of Sunday morning cruises and car show drives.
I figured the distributor & module were the problem, since they are what was on the car when I bought it in 1999.  The dist. was installed sometime in the early 90's and has upwards of 150,000 miles on it. Now that the car barely sees over 3,000 miles a year she's deciding to give me problems!
Chris
Post by: softtouch on October 24, 2006, 04:09:38 PM
Any codes?
Am I correct in thinking that CFI engines do not have an IAC?
Is the '87 3.8 or 5.0 CFI?
Post by: greg w on October 24, 2006, 08:00:15 PM
does sound like the throttle position sensor to me as well
Post by: CougarSE on October 24, 2006, 09:36:20 PM
87 V6 car would be CFI,
And have you pulled KOER KOEO codes??  Please do so unless you like to lessen the load in your wallet.
Post by: Chris1987LX on October 24, 2006, 10:39:43 PM
Thanks again.
We didn't get any codes from the car when we did the test.  I took the dist. back tonight and they noticed it was defective, so they ordered me another.  Hopefully it will be the right one.
Is there a test for the TPS?
Chris
Post by: greg w on October 25, 2006, 09:41:27 PM
there is a test for voltage.  If I remember right its in the FAQ's section.  somebody please correct me if I'm wrong.
Post by: jcassity on October 29, 2006, 01:08:47 AM
Quote from: Chris1987LX;109920
Thanks again.
Hey chris!!!
so,, you gotta be kidding us ,right,,,?  Are you nucking futs? (jk)
you know this stuff dood:grinno:
probe the green wire with a stick pin and clip your red meter lead to it.  Ground your black lead. Its best to have a meter with a needle (buttstuffog) vs the digital meter for this test but either will do.  Set the meter to dc volts.  turn on the ign switch but dont start.
move up to the engine bay and manually move the trottle linkage slowly,,,,,,,,look for less than a volt before you move the linkage and it should perfectly increase in voltage as you increase the trottle.  It will top out at a level that varys with different TPS's that i have noticed.  I would like to say that yours will top out at 4.6vdc but i have tossed ones in the trash that only top out at 4.4 or less.
you can check by resistance only by setting your meter to ohms (5k range) and read between the green to black and then from the green to orange.  these two checks will require you to manually move the linkage as well.  when you get the max value on each of the two resistance checks see if they are equal.  Add these two values together and you should equal the value on the third check which is from the black to orange.
Post by: jcassity on October 29, 2006, 01:16:47 AM
Quote from: softtouch;109849
Any codes?
Sort of kind of,,,,,,,,,,, same principle,, just located in exterior completely whereas the IAC is mounted partially hidden in the upper intake on an 88 3.8 and the SEFI 5.0's
the IAC you speak of is our idle control motor assembly. Its actually call an ISC.
