Technical => Engine Tech => Topic started by: tbirdera on October 14, 2006, 06:01:57 PM
Title: changed TPS sensor quick???
Post by: tbirdera on October 14, 2006, 06:01:57 PM
1988 t bird 5.0 aod
Well I just change the TPS sensor today the sensor "thats on the throttle body" cause the car was stalling. The brand of it was kEM. My question is there is a whole in the middle of the sensor and does it need to be covered? cause it  came like that and the car drives fine with out it covered. I ask this cause my old one was covered.
Do i need to cover it? If so with what??
ERIC
Post by: Chuck W on October 14, 2006, 06:57:12 PM
Huh?  Hole in the middle?
Did you adjust the TPS voltage after you installed the new one?
Post by: tbirdera on October 14, 2006, 07:15:54 PM
how do u adjust it?
Post by: CougarSE on October 14, 2006, 07:28:09 PM
The TPS on the 83 has a hole in its center for one of those goofy stupid idle things...
Post by: Chuck W on October 14, 2006, 08:11:25 PM
Quote from: tbirdera;108497
how do u adjust it?
Go to the Tech Articles section on NATO (http://www.turbotbird.com) and read for yourself.  THe procedure is outlined for a 2.3T, but it's all the same.  It's also been discussed here several times too.
Post by: tbirdera on October 15, 2006, 04:29:38 AM
so the information about what it says to do and how to set the rpm should be the same???
Post by: MasterBlaster on October 15, 2006, 08:28:32 AM
The older sensors for CFI cars had the horizontal throttle shaft going right through the middle; I wouldn't be surprised if the newer versions just glued a plastic cap over the (now vertical) hole to keep dust and other  out.
Post by: thunderjet302 on October 15, 2006, 03:53:08 PM
Just my :2c: but get a Ford TPS. When I put the HO upper and TB on mine 2 years ago I bought a new GP Sorenson TPS from Advance Auto. My car was running kinda funky so I checked the TPS and sure enough it had a flat spot. So I put the 19 year old TPS on from my stock TB and low and behold after adjusting it the car ran 1,000 times better.
