General => General Fox T-Bird/Cougar Discussion => Topic started by: Redheadfoxx on September 21, 2006, 05:11:23 PM
Title: CLEAR CORNER questions...
Post by: Redheadfoxx on September 21, 2006, 05:11:23 PM
I've heard from people how to do this with Mustangs and now Tbirds. But I Have never seen any pics of how it's done. You're supposed to cut the side with a dremel and then pull the amber reflector out. But how do you slide it out the very thin cut from the dremel? How large of a "cut" do I need to make?
Any photos of the process anywhere?
Post by: Clayton on September 21, 2006, 05:49:50 PM
actually, i just pryed mine apart.. the glue isnt very stong after 18 or so years and it kinda just popped out... and if you do pop it apart.. clothespins work great for lodin them together
Post by: Redheadfoxx on September 23, 2006, 07:41:05 PM
Anyone else have any experience?
Post by: turbo88 on September 23, 2006, 07:46:47 PM
I pulled mine apart carfully using a exacto knife, i used some automotive goop to reattach the base/lens together after i removed the amber slide. Still havent put them on, I probably am going to end up buying some clear turn signal lamps that light up amber. . . if i can find some.
