Technical => Engine Tech => Topic started by: tc² on September 16, 2006, 05:51:23 PM
Title: Engine Trouble
Post by: tc² on September 16, 2006, 05:51:23 PM
Yesterday as soon as I accelerated I wasn't getting full boost and the engine was feeling real doggy, so I parked it.  Basically it seems like I'm only firing on 2 cylinders and there is a clicking sound coming from the top of the engine.  Any ideas?
Post by: ipsd on September 16, 2006, 06:37:01 PM
So how much boost are you getting compared to normal? Also are you shure that the clicking sounds isn't the injectors? double check your timing maybe the belt jumped a tooth.
Post by: Clayton on September 16, 2006, 06:37:10 PM
in need of new spark plug wires?
Post by: grutinator on September 16, 2006, 06:41:16 PM
double check your oil and oil pressure, make shure they arent low, oil my not be circulating 100% to the top of the engine and the turbo, probably not, but its not something to be overlooked
Post by: TurboCoupe50 on September 16, 2006, 09:56:01 PM
Ticking huh?? Sounds like its time for a compression check, you may have popped a head gasket...
Post by: *MAYHEM* on September 17, 2006, 10:07:59 PM
Quote from: tc²;104204
How many miles on it? If you're over 75K, you may need to replace the timing belt. Happened on my '86.  'Cept when it happened it did that for ten seconds then died.
Post by: ipsd on September 17, 2006, 11:16:53 PM
The more I think about it sounds like a boost leak. Lower than normal power and doggy. I had a cracked hose on mine. It had py idle and low boost.
Post by: tbirdscott on September 18, 2006, 12:41:35 AM
Do these engines have a knock sensor? if so the top end tic may be sending it false readings.
Post by: ipsd on September 18, 2006, 02:07:02 AM
yep they have knock sensor. It is in the lower intake. It is possible to get false readings with it. Just unhook it and go for a ride. If the power is back you are making some sort of noise that is doesn't like.
Post by: stuntmannick on September 18, 2006, 02:17:00 AM
+1 on the head gasket
Post by: tc² on September 20, 2006, 11:14:10 AM
As for all of these issues:
I'm running about 9 lbs under full load as opposed to 11.
Tried new plug wires to no avail, however when I disconnect the wire going to the cylinder closest to the front of the car, the clicking stops.
Oil/oil pressure is good.
Don't think it's a head gasket... no coolant in oil.
Car runs the same with/without KS.
Post by: Chuck W on September 20, 2006, 11:54:03 AM
You pull the #1 plug wire and the clicking stops?  Does the engine run the same?  What happens when you pull the other plug wires?  Have you pulled the plugs?
Sounds like a dead hole....could be a HG.
Post by: tc² on September 20, 2006, 11:59:42 AM
Yes, that is correct.  The engine runs less rough with #1 plug wire pulled, the rpms rise slightly also.  I have not pulled the plugs.
Post by: Chuck W on September 20, 2006, 12:41:04 PM
Pull the plugs...that's weird.
Post by: Clayton on September 20, 2006, 03:26:58 PM
fouled or bridges sparkplug?
and as i said... time for new wires
Post by: tc² on September 21, 2006, 08:51:15 PM
She lives!  Looked at the #1 plug, it looked like the car was running rich but no probs other than that.  So I pulled the valve cover and sure enough, I jumped a follower on the #1 cylinder.  The cam was worn way down (like everything else) and it managed to pop out of place and was rattling around.  Used a long screwdriver and a mallet to pop it back on, and she runs like a champ.  I'm going to overhaul the engine here not too far off so I'll just have to resist openin' her up too much until then.  Thanks for all the advice.  Once again, FTCF comes through!
