Technical => Suspension/Steering => Topic started by: bigbob on September 06, 2006, 08:02:33 PM
Title: 87 tbird biggest wheel/tire combo
Post by: bigbob on September 06, 2006, 08:02:33 PM
hey guys im new here! killer site. let me ask my question and then ill tell ya a bit abotu the project.
what is the biggest tire/wheel you can fit under an 87 tbird{non tc- has no quad shocks} without minitubs? i have seen 10.5 meat on 10 inch rims on fox mustangs. i have been told the t bird isnt the same fox tho. from messuring the wheel well it doesnt look like a big hammer will make a 10 inch rim fit without any tire on it. can i atleast get away with an 8 inch rim with a 325/50 radial or something of that nature?
the project is 521 ci bbf {250shot of n20} on my little sleepy bird:evilgrin:  haha. body work leaves much to be desired. has no interior {make her as light as i can, hopfully under 3k with me} gunna be my little sleeper. looking for low 9's on a full spool with 4.10's {9'' read} and either a turbo 400 or a glide. ill get pictures up threwout the build. i have the bottem end, the block, heads and my 750$ tbird find.  thanks for your time fellas.
Post by: Blown306Cougar on September 06, 2006, 08:46:01 PM
i just recently swithed to 275/60/15's on the rear. and they seem to hook better then the 295/50/15's i used for years.. i was able to fit a tire like a 295/50/15 because i used a fox body mustang rearend.. it bolts up at the same points as the Tbird/Cougar. but the axle tubes are 3/4" shorter on each end.. and just so you know the T/bird/Cougar wheel wells are larger then mustang wheel wells..
and i used those tires on stock 15/7's and weld draglites 15/8's
and i'm going back to the stock rim soon with 275/60/15's mounted on the rears..
i know meny people that owned fox body mustangs and 275/50/15's just fit and rub just a little on the outer QTR and to fit. 295/50'15's you have to beat the death out of the inner QTR to get them to fit. and will still rub a little..
check out http://www.coolcats.net/catjam/
and you should see more picks of my cougar with the tires i stated on my car
and other cars with diffrent tire sizes
Nick
Post by: Blown306Cougar on September 06, 2006, 08:47:55 PM
weld pictures
Post by: bigbob on September 06, 2006, 09:34:02 PM
thanks abunch for the reply and pics nick! any one else got some experience for me?
Post by: 87badbird2613 on September 07, 2006, 02:06:52 AM
the first pic is a 275/60/15 on a 15x8 weld draglite- turbocoupe disk brake 8.8
the second pic is a 275/50/15 on a 15/8 draglite with a mustang 8.8
i have seen guys with 325/50s on draglites but im not sure the exact offset
Post by: bduly on September 07, 2006, 04:00:00 AM
275-40s on 17x9 imitation cobra r's (fox mustang offset) in the rear with no rubbing issues at all.
Post by: SLEEPER T-BIRD 87 on September 09, 2006, 02:30:59 PM
Im fixing to put a 325/50/15 under my bird on a 15x10 with a 6.0 backspace. :pbb:
i had a 17x10.5 on the rear before with a 315/35/17
Post by: Uncleford on September 09, 2006, 05:29:06 PM
Are the tires going to stick out? If it all tucks in it should look great. Post the pics...
Post by: 88sportcoupe on September 09, 2006, 06:08:27 PM
Quote from: 87badbird2613;102795
Do you know the offset of those rims with the 275s?
Post by: SLEEPER T-BIRD 87 on September 09, 2006, 10:38:46 PM
Quote from: Uncleford;103163
Dont have any pics yet waiting on the wheels to arrive. Hopefully this week.
Post by: 87badbird2613 on September 10, 2006, 04:49:24 AM
Quote from: 88sportcoupe;103170
5.5 backspacing
Post by: *MAYHEM* on September 17, 2006, 02:40:02 PM
Who is still manufacturing 275/50/15's? I'd be really interested in getting a set for my cat to last until the big work starts next spring.
Post by: SRBird on September 19, 2006, 11:00:57 PM
87badbird2613 please post what you did to modified your rear taillights. Their wicked! I have a spare set that I'd like to do the same with. Thanks
Post by: MasterBlaster on September 20, 2006, 07:45:02 AM
I've only got a few tire lists here, but... BFGoodrich Radial T/A
Here's one (if it works): http://www.customwheelsdirect.com/tires_brand/BFGoodrich.php?PHPSESSID=8709f171fb71140525965469925a2ab6&brand_path_file=BFGoodrich.php&tire_w=275&tire_h=50&tire_d=15&pricerange=all&search=Refine+Search
Post by: *MAYHEM* on September 20, 2006, 09:29:59 AM
Quote from: MasterBlaster;104676
After a couple hours of googling I found the T/As. Tire Rack has them for $106. Also found some spoogeho 295s for $72. Only SR rated but I only intend them to get me through the winter.
Post by: DVP on September 20, 2006, 09:32:07 AM
what would i have to do to fit some 4lug 17x10.5 rims on the back of my 86? or is it possible? can get them for a deal 2 or four but i know they wont fit the front.
not to hack
Post by: DVP on September 20, 2006, 09:37:52 AM
can i make a 10.5 cobra r fit the back of my 86? i can get them on the deal.
Post by: cougarman on October 19, 2006, 08:36:25 PM
well i got 18x9's in there with no rubbing and alot of extra space,
Post by: 84 Fila on October 19, 2006, 08:51:55 PM
Holy shiznite, that looks awsome
Post by: Vantage08 on October 19, 2006, 10:16:14 PM
it doesn't rub when you turn?
Post by: 46Tbird on October 20, 2006, 11:53:50 AM
Cougarman, what axle are you running (stock Tbird with 5lug axles or Mustang) and what is the offset on those wheels?
Thanks..
Post by: cougarman on October 20, 2006, 03:09:53 PM
thanks, nope i can go full lock and no rubbing at all, i have a tc axel with 96 mustang shafts the offset i believe is the +26 they were for the 99+ mustangs which have more backspcing due to the increased track with of those cars
