General => General Fox T-Bird/Cougar Discussion => Topic started by: 88BlueBird on September 06, 2006, 12:35:32 PM
Title: Bracket Bushings for TV cable
Post by: 88BlueBird on September 06, 2006, 12:35:32 PM
Does anyone know if Ford still sells the plastic bushings that go into the TV cable bracket?  This bracket is mounted to trans bell housing.  Has anyone replaced these parts before?
Post by: cougarcragar on September 06, 2006, 12:56:00 PM
I had to replace that bushing back in 2001 or so. I went to the local Ford dealership, asked them about it, and they gave it to me. I have no idea if they still make 'em. Try calling your local Ford dealership and asking the service department. Get two of 'em if you can. ;)
Post by: vinnietbird on September 07, 2006, 12:11:12 AM
They still sell them.They are made of brass now.If you send me your address,I'll send you one.I have a couple in a bowl on the bench.
Post by: MasterBlaster on September 07, 2006, 08:58:42 AM
Are there bushings down there too? It's usually the ones up at the throttle body that go bad. My TV linkage seems to be all metal rods and little ball-joints. Are you perhaps referring to the shift linkage, specifically the bushing in the oily yellow bracket that the cross-bar goes through (bushing hidden by the slotted part of the "Shifter link"?
Post by: vinnietbird on September 07, 2006, 09:05:15 AM
My mistake,I was thinking the bushing on the throttlebody.I may have the rod assembly,I'll check.
Post by: 88BlueBird on September 07, 2006, 01:15:16 PM
Wow..awesome picture MasterBlaster.  In your pic, the plastic bushings (mine were green plastic) go into the bracket that the "TV Links" are attached to. The bushings allow the bracket to rotate on the bolt, which is attached to transmission. I just checked with Ford parts and the bushings are discontinued :(
Post by: MasterBlaster on September 08, 2006, 08:46:03 AM
Okay, more of a "bellcrank" than a bracket.
Mine are the same color. I kicked up the green to show them.
Post by: 88BlueBird on September 08, 2006, 08:49:01 PM
Yep....those are the ones.  I'm trying to have some custom made and I will let everyone know how they turn out.
